Hello everyone.
I wanted to reconfigure everything from HA supervisor to docker, since I had a big mess of everything and I couldn’t update to the latest version either, and thus start everything again.
But my surprise following the manual is that in the last installation step of homeassistant-supervised.deb I get the following error and I don’t know what could be happening, I have purged NetworkManager and reinstalled but nothing. I’M DESPERATE!
(Leyendo la base de datos … 69308 ficheros o directorios instalados actualmente.)
Preparando para desempaquetar homeassistant-supervised.deb …
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[error] Raspbian GNU/Linux 11 (bullseye) is not supported!
dpkg: error al procesar el archivo homeassistant-supervised.deb (–install):
el subproceso nuevo paquete homeassistant-supervised script pre-installation devolvió el código de salida de error 1
[info] Undo divert on abort-install
No hay un desvío paradesviación de /etc/NetworkManager/NetworkManager.conf a /etc/NetworkManager/NetworkManager.conf.real por homeassistant-supervised', no se ha eliminado ninguno. No hay un desvío paradesviación de /etc/NetworkManager/system-connections/default a /etc/NetworkManager/system-connections/default.real por homeassistant-supervised’, no se ha eliminado ninguno.
No hay un desvío paradesviación de /etc/docker/daemon.json a /etc/docker/daemon.json.real por homeassistant-supervised', no se ha eliminado ninguno. No hay un desvío paradesviación de /etc/network/interfaces a /etc/network/interfaces.real por homeassistant-supervised’, no se ha eliminado ninguno.
[info] Resetting debconf selections
[info] Removal complete, due to the complexity of this installation method,
[info] you will need to manually remove the containers created by the supervisor
Se encontraron errores al procesar:
can you help me,
Thank you
