I need help! why don't see smartlife integration?
I need help! why don’t see smartlife integration?
Where do I go wrong?
I installed smart life integration as indicated here: How to Install Smart Life Integration (Beta)-Tuya Developer Platform-Tuya Developer
martino@ThinkPad-Twist:~/home-assistant/config$ ll
totale 120672
drwxrwxr-x 8 martino martino     4096 ago  5 18:30 ./
drwxrwxr-x 3 martino martino     4096 ago  5 18:30 ../
-rw-r--r-- 1 root    root        1180 lug  7 09:12 automations.yaml
drwxr-xr-x 4 root    root        4096 lug  6 10:13 blueprints/
drwxr-xr-x 2 root    root        4096 lug  6 10:13 .cloud/
-rw-r--r-- 1 root    root         265 lug  6 10:13 configuration.yaml
drwxr-xr-x 2 root    root        4096 lug  6 10:13 deps/
-rw-r--r-- 1 root    root           8 lug  6 10:13 .HA_VERSION
-rw-r--r-- 1 root    root    24526366 lug 11 20:30 home-assistant.log
-rw-r--r-- 1 root    root    31887925 lug  9 06:22 home-assistant.log.1
-rw-r--r-- 1 root    root    67088384 lug 11 21:34 home-assistant_v2.db
-rw-r--r-- 1 root    root           0 lug  6 10:13 scenes.yaml
-rw-r--r-- 1 root    root           0 lug  6 10:13 scripts.yaml
-rw-r--r-- 1 root    root         161 lug  6 10:13 secrets.yaml
drwxrwxr-x 3 martino martino     4096 ago  4 18:39 smartlife/
drwxr-xr-x 2 root    root        4096 lug 11 21:34 .storage/
drwxr-xr-x 2 root    root        4096 lug  6 10:13 tts/
Use the official Tuya integration, it works with the smartlife app too.
It is still in beta, maybe better to post issues in their Github. But looking at the install specs, it is missing a reboot. If you copy the source, you need to reboot before it is picked up.
That is not the problem, he put it in /smartlife, not in /custom_components/smartlife, but the beta is really abandoned because they merged everything in the official Tuya integration.
That BETA Integration is no longer valid. if you go to the github page (GitHub - tuya/tuya-smart-life: Tuya Smart Life Home Assistant Integration), you will see the following.
:warning: This project has now officially been integrated into the Home Assistant official project core repository, corresponding to version 2024.2. This project will no longer continue to iterate. Subsequent iterations and support will be carried out under the Home Assistant official project. If you have any questions, please communicate at Issues · home-assistant/core · GitHub. Thank you.
use the official integration here Tuya - Home Assistant
ok!
but I have problem with Tuya - Home Assistant.
After a few days the integration no longer works.
When I try to reload the integration I see this error:
Home Assistant Core
2024-08-07 21:11:17.246 ERROR (MainThread) [homeassistant.components.homeassistant_alerts.coordinator] Error requesting homeassistant_alerts data: Cannot connect to host alerts.home-assistant.io:443 ssl:default [None]
2024-08-07 21:11:46.298 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 72, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.12/socket.py", line 964, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 404, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1060, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 363, in connect
self.sock = conn = self._new_conn()
File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7987e0fafc50>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 667, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 801, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 594, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='apigw.iotbing.com', port=443): Max retries exceeded with url: /v1.0/m/life/home-assistant/qrcode/tokens?clientid=HA_3y9q4ak7g4ephrvke&usercode=Cara4qi&schema=haauthorize (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7987e0fafc50>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 85, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
return await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 368, in async_configure
result = await self._async_configure(flow_id, user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 415, in _async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 518, in _async_handle_step
result: _FlowResultT = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/tuya/config_flow.py", line 49, in async_step_user
success, response = await self.__async_get_qr_code(
File "/usr/src/homeassistant/homeassistant/components/tuya/config_flow.py", line 201, in __async_get_qr_code
response = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.12/site-packages/tuya_sharing/user.py", line 16, in qr_code
response = self.session.request("POST",
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 700, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='apigw.iotbing.com', port=443): Max retries exceeded with url: /v1.0/m/life/home-assistant/qrcode/tokens?clientid=HA_3y9q4ak7g4ephrvke&usercode=xxxxxx&schema=haauthorize (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7987e0fafc50>: Failed to establish a new connection: [Errno -3] Try again'))
I read that with Tuya the authentication token expires and needs to be renewed. Is this true?
I have something similar. After X time the statuses of switches are not updated anymore. When I reboot home assistant then it works fine for X time. X is somewhere of 24 to 48 hours. What to check?
