I need help with a little project
Hi all
I need a help with a little project, I scrape some events from the web and store them in sensors “sensor.match_time_one” which is the time of the event.
I need to create another sensor showing “Next event”
This doe not work, just to demonstrate the idea
can someone please show me the correct approach to do this
binary_sensor:
  - platform: tod
    time: “sensor.match_time_one”
    before_offset: 15 minutes
    after_offset: 20 minutes
  - platform: tod
    time: “sensor.match_time_two”
  - platform: tod
    time: “sensor.match_time_three”
    sensors:
      time_of_day:
        friendly_name: "Next event is”
        value_template: >-
          {% if is_state('sensor.match_time_one,'on') %}
            First Event
          {% elif is_state('sensor.match_time_two,’on') %}
            Second Event
          {% else %}
            Third Event
          {% endif %}
:pray:
thank for the reply, as I said that was not a code, just to demonstrate the idea
instead of a tod binary sensor you will likely need to create a template binary sensor to tell you you are in the window of each event.
post the state of your “match_time_one” sensor.
sensor.match_time_one output is 18:00
same thing with other sensors, just hours and minutes like 14:30
create a template binary_sensor (I’m using the legacy format here):
binary_sensor:
    value_template: "{{ today_at(states('sensor.match_time_one')) - timedelta(minutes = 15) < now() < today_at( states('sensor.match_time_one') ) + timedelta(minutes = 20) }}"
that will be true 15 minutes before till 20 minutes after the “match_time_one”
thanks that was really helpful and good start
