I have a washer automation that checks if anybody is home to notify them that the washer is done
I have it coded in a template that look for our device trackers states.
If I am home = notify me
If my wife is home = notify my wife
if we are both home = notify us both
the one I am struggling with is if we both are not home, the automation still triggers but since it doesn’t know who to notify since both of us are NOT home it fails and stops.
Is there a way to have it hold on to the notify service until at least one of us show up at home and then run the action template?
here is the notify template
alias: Send alert when Washing Machine is finished
description: ''
- platform: state
entity_id: sensor.washing_machine_status
to: Idle
for:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
condition: []
- service: >
{% if is_state('device_tracker.iphone_12_pro_max', 'home') and
is_state('device_tracker.danas_iphone', 'home') %}
notify.tarik_and_dana
{% elif is_state('device_tracker.danas_iphone', 'home') %}
notify.dana
{% elif is_state('device_tracker.iphone_12_pro_max', 'home') %}
notify.tarik
{% else %} notify.dana {% endif %}
message: The washer is finished! Make sure to move clothes to the Dryer
- service: notify.alexa_media_laundry
message: >-
The Washer is finished! Please make sure to move the clothes to the
Dryer as soon as possible
type: announce
method: tts
I’m not aware of any built in way to do this. However, you could set a helper boolean if nobody is home. Then, have another automation that checks if that boolean is set when someone gets home and notifies them if so.
it’s hard to know since you only posted part of the automation…
but you could use one (or both) of the device trackers going to “home” as a trigger for the automation.
then in the conditions check that the washer is done (however you have accomplished that - again without any more info it’s hard to give any concrete advice) before you run the notification action.
Updated op with whole automation. I am using washer status sensor to change it to idle when a sonoff s31 drops below a certain power and then the input_ washer _ boolean trigger the alert when its set to idle
I think you perhaps should write this automation in a different way, but you could put a wait for trigger after the main sequence and then run the sequence again. Just put a small delay in the “no one home” option.
wait_for_trigger:
- platform: state
entity_id: person.self
to: home
- platform: state
entity_id: person.wife
to: home
Oh, good idea, I forgot about wait_for_trigger. So, the action sequence could just be something like the following:
- choose:
- alias: "If nobody is home, wait"
conditions:
- condition: state
entity_id:
- device_tracker.danas_iphone
- device_tracker.iphone_12_pro_max
state: not_home
sequence:
- wait_for_trigger:
- platform: state
entity_id:
to: home
- service: >-
notify.dana
notify.tarik
{% endif %}
message: >-
type: announce
method: tts
Nice! One small tweak to recommend. In the “nobody home” leg of the choose block, put the wait for trigger. In the default leg, put just a delay of one second, and then put all of the notifying etc. after the choose block. That way the action templates don’t need to be reproduced.
I may be forgetting the form that choose needs to be in, but, is that not what I wrote? The choose sequence is only entered if nobody is home. Otherwise, the condition isn’t met and the sequence proceeds on to notify. No need for template reproduction. Unless you’re saying to just have the choose define every action, since the templates are basically reproducing a choose.
Also, not sure what the default delay of one second is for.
If you like it like that, that’s fine, but it’s personally easier for me to read in the form I used:
condition:
condition: state
entity_id:
state: not_home
If you want to use those and conditions instead, yours are a bit malformed:
condition:
alias: "Paulus home AND temperature below 20"
condition: and
conditions:
- condition: state
entity_id: "device_tracker.paulus"
state: "home"
- condition: numeric_state
entity_id: "sensor.temperature"
below: 20
I’m also curious what @Dolores will say the delay is for.
You’re certainly on the right track, especially after those few points are acknowledged!
EDIT: Oh, I also think states are case-sensitive, so you’ll probably want to use home instead of Home.
- conditions:
- condition: state
entity_id:
state: not_home
sequence:
- wait_for_trigger:
- platform: state
entity_id:
to: home
for:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
continue_on_timeout: false```
then run the service action after this
Only thing would be that five minute time out. That means that, unless either of you get home within five minutes of the trigger, you won’t be notified. If that’s the behavior that you want, then it should be fine!
My original statement was incorrect, please ignore.
oh shoot, I meant for it to be 5 minutes after we get home and device trackers switch to home because we might not hear the tts announcement if it’s instant
