I need help with ESPHome sensor
Hello, I have a battery powered multisensor with ESP32 (PIR, sound, temp, humidity, battery, CO2).
What I want to do in the sensor yaml file is something like this :
  • Esp32 is in deep sleep for let’s say 30sec.
  • When is waking up from deep sleep to turn on the pir sensor power(this is already done for 5 seconds) and if the PIR sensor feels movement to go further with other tests(battery, temp, humidity,etc) and also to connect to WIFI and to send the values and deep sleep … if PIR doesn’t feel any movement (in that 5 seconds of being awake) to go to deep sleep again instantly (without turning on WIFI, scanning wifi networks and stuff) to save the battery.
    Can you help me to implement this “if - that - else” ?
This is my yaml file:
esphome:
  friendly_name: officesense1
  includes:
    - "cm1106.h"
  on_boot:
      priority: 250
      then:
        - switch.turn_on: PIR_power
        - delay: 5s
        - switch.turn_off: PIR_power
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: "oelCUfp7IcuXcD908fWWcqSFw="
ota:
  password: "65c81d63a6a545b8808"
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  # power_save_mode: HIGH
  manual_ip:
    static_ip: 192.168.178.32
    gateway: 192.168.178.1
    subnet: 255.255.255.0
  ap:
    ssid: "Officesense1 Fallback Hotspot"
captive_portal:
# i2c:
#   sda: 21
#   scl: 22
#   scan: true
#   id: bus_a
# uart:
#   rx_pin: 16
#   tx_pin: 17
#   baud_rate: 9600
#   id: cm1106_uart
  # - platform: hdc1080
  #   temperature:
  #     name: "temperature"
  #   humidity:
  #     name: "humidity"
  #   update_interval: 60s
  # - platform: custom
  #   lambda: |-
  #     auto cm1106Sensor = new CM1106Sensor(id(cm1106_uart), 10000);
  #     App.register_component(cm1106Sensor);
  #     return {cm1106Sensor};
  #   sensors:
  #   - name: "CO₂ Sensor"
  #     accuracy_decimals: 0
  #     unit_of_measurement: "ppm"
  #     icon: "mdi:molecule-co2"
  - platform: adc
    pin: A5
    icon: "mdi:battery-alert"
    accuracy_decimals: 2
    update_interval: 1s
    attenuation: 11dB
    filters:
      - multiply: 2.0
binary_sensor:
  - platform: gpio
    pin: 18
    device_class: motion
switch:
#   lambda: |-
#     auto cm1106Calib = new CM1106CalibrateSwitch(id(cm1106_uart));
#     App.register_component(cm1106Calib);
#     return {cm1106Calib};
#   switches:
#   - name: "CM1106 Zero Calibration"
- platform: gpio
  name: "PIR power "
  pin: 13
  icon: "mdi:eye"
- platform: restart
  name: "Living Room Restart"
deep_sleep:
  run_duration: 10s
  sleep_duration: 30s
I’m not sure you can force those sensors to be manually update only.
If I was designing something like this I would use a 3.3V PIR to trigger the interrupt pin on an ESP32, to wake it out of long term deep sleep. Have a read about ESP32 Wakeup Pin Mode.
I have seen other suggestions for an ESP8266 where the PIR trips a transistor circuit to latch power on. A quick google found this discussion: PIR sensor only to be powered and it turns on another power supply and load.
I personally would go with the wakeup pin. That’s how my mailbox sensor works.
