I have a RFID reader for cats, it’s UART and I know it’s wired up correctly, however the only example of a custom UART is text reader, my needs are different.
I’m using an ESP32.
The RFID reader sends 13 codes with values from 0 to 255, no LF, no CR. The feed isn’t constant, only when the tag near.
The first number is always 170 and the last is always 187.
I would like to be able to read these numbers and append them as one long number and export as a text_sensor.
That would involve:
Starting at 170 (although it should always start with 170)
Ending at 187 (or just a counter to 13)
Converting int to char
Adding the digits to the end of a char
Sending that back as a text sensor
I won’t lie, I’ve been trying to get this to work all weekend, I’ve got it to report the numbers one at a time as a sensor(not text). I just can’t get my head around it, I can do it in arduino, but not this C++ stuff.
Sorted, this does the job, only took me about 5 days!
#include "esphome.h"
class BondcoTagReader : public Component, public UARTDevice, public TextSensor {
public:
BondcoTagReader(UARTComponent *parent) : UARTDevice(parent) {}
void setup() override {
// nothing to do here
int readtag(int dave, char *buffer) {
static int len = 0; // create static int for buffer length
if (dave == 170) { // if start of tag (170)
len = 0; // reset buffer count
char chartemp[3]; // create a temporary char array
sprintf(chartemp, "%d", dave); // convert int to char
if(dave < 10) { // if only 1 char
chartemp[2] = chartemp[0]; // copy char2 to char0
chartemp[1] = *"0"; // fill char1 with 0
chartemp[0] = *"0"; // fill char0 with 0
} else if (dave < 100){ // if only 2 chars
chartemp[2] = chartemp[1]; // copy char2 to char1
chartemp[1] = chartemp[0]; // copy char1 to char0
chartemp[0] = *"0"; // fill char1 with 0
for (int j = 0; j < 3; j++) { // copy from temporary chars to buffer array
buffer[len+j] = chartemp[j];
len = len + 3; // add number of chars to buffer count
if (dave == 187) { // if end of tag (187)
if (len > 37) // if length of len > 37
{ // all is good
return 1; // return 1 to if statement below
} else { // else
return -1; // return -1 (failed)
return -1; // return -1 (failed) to if statement below
void loop() override {
static char buffer[40];
while (available()) {
if(readtag(read(), buffer) > 0) {
publish_state(buffer);
buffer[0] = '\0';
