I’m new to HA and I’m trying to read some values from my heat pump that sets up a local webpage. I have found the numbers I’m looking for but I can’t manage to access them with scrape.
The value I’m trying to access is (in this case) 22 on the highlighted row.
This is what I’ve got so far:
- platform: scrape
resource: https://192.168.68.120/main.htm
select: ".screen@p2HC_div > div:nth-child(6)"
value_template: '{{ value I int }}'
unit_of_measurement: "°C"
But the sensor.framledning won’t even show up. I also tried
select: ".cp115i5:is(div)"
like in an example I found in the documentation but it didn’t work (the example worked).
Really grateful for any help!
