When compiling this:
# This is the actual reading of the various sensors
- platform: adc
pin: A0
update_interval: 0.1s
internal: true # Don't expose this sensor to HA, the template sensors will do that
accuracy_decimals: 1
filters:
- sliding_window_moving_average: # averages the last 10 results, probably overkill
window_size: 10
send_every: 10
- lambda: |-
if (x > id(plant_soil_moisture_setpoint)) {
return 0;
} else if (x < 0.264) {
return 100;
} else {
return (id(plant_soil_moisture_setpoint)-x) / (id(plant_soil_moisture_setpoint)-0.264) * 100.0; // use a linear fit for any values in between
- platform: homeassistant
name: "Plant soil moisture setpoint"
entity_id: sensor.plant_soil_moisture_setpoint # From HA input_number
I’m getting the following errors:
src/main.cpp: In lambda function:
src/main.cpp:456:15: error: invalid operands of types 'float' and 'esphome::homeassistant::HomeassistantSensor*' to binary 'operator>'
if (x > plant_soil_moisture_setpoint) {
src/main.cpp:461:46: error: invalid operands of types 'esphome::homeassistant::HomeassistantSensor*' and 'float' to binary 'operator-'
return (plant_soil_moisture_setpoint-x) / (plant_soil_moisture_setpoint-0.264) * 100.0;
src/main.cpp:461:81: error: invalid operands of types 'esphome::homeassistant::HomeassistantSensor*' and 'double' to binary 'operator-'
src/main.cpp:463:3: warning: control reaches end of non-void function [-Wreturn-type]
I’m pretty sure this has something to do with mixing float and int in the comparisons but I can’t figure out how to fix it.
Any ideas?
