I have been getting “Unhealthy system - Setup failed” for several months now.
Listed as critical and link to “Setup of the Supervisor failed”
Sometimes intermittent, others times when there is an electricity outage and the system restarts. HA Supervisor restart fixes this problem, but I’d like to find the root cause.
Home Assistant 2023.1.0
Supervisor 2022.12.1
Operating System 9.4
Frontend 20230104.0 - latest
I’m always on the latest version. log file from a power outage this morning.
2023-01-06 06:58:00.103 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=845 from 2023-01-04 21:40:52)
2023-01-06 06:58:18.161 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2023-01-06 06:58:18.433 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2023-01-06 06:58:28.520 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2023-01-06 06:58:33.521 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2023-01-06 06:58:42.541 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2023-01-06 06:58:48.551 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2023-01-06 06:59:02.566 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2023-01-06 06:59:03.575 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2023-01-06 06:59:04.202 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2023-01-06 06:59:18.880 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2023-01-06 06:59:29.596 WARNING (MainThread) [hass_nabucasa.iot] Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
2023-01-06 06:59:33.907 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2023-01-06 06:59:48.936 ERROR (MainThread) [hass_nabucasa.remote] Can't update remote details from Home Assistant cloud
2023-01-06 06:59:53.375 ERROR (SyncWorker_2) [homeassistant.util.package] Unable to install package beautifulsoup4==4.7.1: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8dba50f0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8dba5390>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8dba7790>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8dbf4eb0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8dbf5d50>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8db1e650>: Failed to establish a new connection: [Errno -3] Try again')': /simple/beautifulsoup4/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8db1d6f0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/beautifulsoup4/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8da52c80>: Failed to establish a new connection: [Errno -3] Try again')': /simple/beautifulsoup4/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8da53370>: Failed to establish a new connection: [Errno -3] Try again')': /simple/beautifulsoup4/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f8da50880>: Failed to establish a new connection: [Errno -3] Try again')': /simple/beautifulsoup4/
ERROR: Could not find a version that satisfies the requirement beautifulsoup4==4.7.1 (from versions: none)
ERROR: No matching distribution found for beautifulsoup4==4.7.1
[notice] A new release of pip available: 22.3 -> 22.3.1
[notice] To update, run: pip install --upgrade pip
2023-01-06 07:00:04.291 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2023-01-06 07:00:19.539 ERROR (MainThread) [homeassistant.components.aftership.sensor] No tracking data found. Check API key is correct: 403 is not valid - 403 - You don't have permission to access AfterShip API. Please upgrade to a Pro plan at https://admin.aftership.com/settings/billing to get access to premium features
2023-01-06 07:00:20.733 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
2023-01-06 07:00:22.825 ERROR (MainThread) [homeassistant.components.sensor] email: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 503, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 729, in async_device_update
await task
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/email/sensor.py", line 257, in update
server = IMAPClient(self.imap_server, use_uid=True, ssl=self.ssl)
File "/usr/local/lib/python3.10/site-packages/imapclient/imapclient.py", line 285, in __init__
self._imap = self._create_IMAP4()
File "/usr/local/lib/python3.10/site-packages/imapclient/imapclient.py", line 322, in _create_IMAP4
return tls.IMAP4_TLS(
File "/usr/local/lib/python3.10/site-packages/imapclient/tls.py", line 44, in __init__
imaplib.IMAP4.__init__(self, host, port)
File "/usr/local/lib/python3.10/imaplib.py", line 202, in __init__
self.open(host, port, timeout)
File "/usr/local/lib/python3.10/site-packages/imapclient/tls.py", line 49, in open
sock = socket.create_connection(
File "/usr/local/lib/python3.10/socket.py", line 824, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/local/lib/python3.10/socket.py", line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
2023-01-06 07:00:23.001 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/17
2023-01-06 07:00:23.011 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/17' (KNX Office HVAC - State)
2023-01-06 07:00:23.014 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/8
2023-01-06 07:00:23.017 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/8' (KNX Family HVAC - State)
2023-01-06 07:00:31.965 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/1
2023-01-06 07:00:31.967 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/1' (KNX Parents HVAC - State)
2023-01-06 07:00:31.970 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/3
2023-01-06 07:00:31.972 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/3' (KNX Noa Gallery HVAC - State)
2023-01-06 07:00:31.975 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.1.131:5555. TcpTimeoutException: Connecting to 192.168.1.131:5555 timed out (1.0 seconds)
2023-01-06 07:00:31.982 WARNING (MainThread) [homeassistant.config_entries] Config entry '192.168.1.131' for androidtv integration not ready yet: Could not connect to Android TV / Fire TV device at 192.168.1.131:5555 using Python ADB implementation with adbkey='/config/.storage/androidtv_adbkey'; Retrying in background
2023-01-06 07:00:33.271 WARNING (MainThread) [homeassistant.components.generic.camera] Loading generic IP camera via configuration.yaml is deprecated, it will be automatically imported. Once you have confirmed correct operation, please remove 'generic' (IP camera) section(s) from configuration.yaml
2023-01-06 07:00:37.265 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/11
2023-01-06 07:00:37.269 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/11' (KNX Gym HVAC - State)
2023-01-06 07:00:37.274 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/12
2023-01-06 07:00:37.278 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/12' (KNX Lobby LR HVAC - State)
2023-01-06 07:00:37.677 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for tuya integration not ready yet: HTTPSConnectionPool(host='openapi.tuyaeu.com', port=443): Max retries exceeded with url: /v1.0/iot-01/associated-users/actions/authorized-login (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f858e5210>: Failed to establish a new connection: [Errno -3] Try again')); Retrying in background
2023-01-06 07:00:39.290 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/16
2023-01-06 07:00:39.294 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/16' (KNX Basement shelter HVAC - State)
2023-01-06 07:00:39.305 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/18
2023-01-06 07:00:39.307 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/18' (KNX wine HVAC - State)
2023-01-06 07:00:40.484 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform xiaomi_tv is taking over 10 seconds.
2023-01-06 07:00:40.879 ERROR (SyncWorker_0) [custom_components.xiaomi_cloud_map_extractor.camera] Unable to log in, check credentials
2023-01-06 07:00:41.311 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 1/1/76
2023-01-06 07:00:41.316 WARNING (MainThread) [xknx.log] Could not sync group address '1/1/76' (Bridge Spots - State)
2023-01-06 07:00:41.320 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 2/0/76
2023-01-06 07:00:41.323 WARNING (MainThread) [xknx.log] Could not sync group address '2/0/76' (Bridge Spots - Brightness)
2023-01-06 07:00:41.468 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xDB37:1:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-01-06 07:00:41.578 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xDB37:1:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-01-06 07:00:42.473 ERROR (MainThread) [homeassistant.components.media_player] Error while setting up xiaomi_tv platform for media_player
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 398, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/usr/local/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f7c8d3580>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.101', port=6095): Max retries exceeded with url: /request?action=isalive (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f7c8d3580>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 289, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/xiaomi_tv/media_player.py", line 55, in setup_platform
add_entities(XiaomiTV(tv, DEFAULT_NAME) for tv in pymitv.Discover().scan())
File "/usr/local/lib/python3.10/site-packages/pymitv/discover.py", line 33, in scan
if self.check_ip(ip_check):
File "/usr/local/lib/python3.10/site-packages/pymitv/discover.py", line 51, in check_ip
request = requests.get(tv_url, timeout=request_timeout)
File "/usr/local/lib/python3.10/site-packages/requests/api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 565, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.101', port=6095): Max retries exceeded with url: /request?action=isalive (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f7c8d3580>: Failed to establish a new connection: [Errno 111] Connection refused'))
2023-01-06 07:00:43.322 WARNING (MainThread) [homeassistant.helpers.entity] Update of camera.xiaomi_cloud_map_extractor is taking over 10 seconds
2023-01-06 07:00:43.605 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/4
2023-01-06 07:00:43.607 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/4' (KNX Kids Bath HVAC - State)
2023-01-06 07:00:43.819 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/6
2023-01-06 07:00:43.822 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/6' (KNX Dina Office HVAC - State)
2023-01-06 07:00:45.611 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 10/1/7
2023-01-06 07:00:45.613 WARNING (MainThread) [xknx.log] Could not sync group address '10/1/7' (KNX Shmaya HVAC - State)
2023-01-06 07:00:52.154 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
2023-01-06 07:00:53.346 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
2023-01-06 07:00:58.347 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
2023-01-06 07:00:58.352 WARNING (MainThread) [homeassistant.helpers.entity] Update of camera.xiaomi_cloud_map_extractor is taking over 10 seconds
2023-01-06 07:01:02.272 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.1.131:5555. TcpTimeoutException: Connecting to 192.168.1.131:5555 timed out (1.0 seconds)
2023-01-06 07:01:08.593 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
2023-01-06 07:01:13.990 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.1.131:5555. TcpTimeoutException: Connecting to 192.168.1.131:5555 timed out (1.0 seconds)
2023-01-06 07:01:21.794 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
2023-01-06 07:01:23.735 WARNING (MainThread) [homeassistant.components.camera] Updating xiaomi_cloud_map_extractor camera took longer than the scheduled update interval 0:00:05
2023-01-06 07:01:24.362 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.lr_temperature_humidity_sensor_temperature (°C) can not be converted to the unit of previously compiled statistics (℃). Generation of long term statistics will be suppressed unless the unit changes back to ℃ or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
2023-01-06 07:01:24.643 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.temperature_and_humidity_sensor_temperature (°C) can not be converted to the unit of previously compiled statistics (℃). Generation of long term statistics will be suppressed unless the unit changes back to ℃ or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
2023-01-06 07:01:24.682 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.temperature_and_humidity_sensor_2_temperature (°C) can not be converted to the unit of previously compiled statistics (℃). Generation of long term statistics will be suppressed unless the unit changes back to ℃ or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
2023-01-06 07:01:24.719 WARNING (Recorder) [homeassistant.components.sensor.recorder] The unit of sensor.temperature_and_humidity_sensor_3_temperature (°C) can not be converted to the unit of previously compiled statistics (℃). Generation of long term statistics will be suppressed unless the unit changes back to ℃ or a compatible unit. Go to https://my.home-assistant.io/redirect/developer_statistics to fix this
2023-01-06 07:01:35.611 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1844:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-01-06 07:01:36.155 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.1.131:5555. TcpTimeoutException: Connecting to 192.168.1.131:5555 timed out (1.0 seconds)
2023-01-06 07:01:39.284 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x247A:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-01-06 07:01:39.860 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1844:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>')]
2023-01-06 07:01:41.832 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x247A:1:0x0300]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-01-06 07:01:42.268 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x247A:1:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-01-06 07:01:42.850 ERROR (MainThread) [custom_components.hacs] <QueueManager> No manifest.json file found 'custom_components/media_player/manifest.json'
2023-01-06 07:01:43.487 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xD76D:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-01-06 07:01:44.491 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xD76D:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2023-01-06 07:01:44.576 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xD76D:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2023-01-06 07:01:45.156 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x1844:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2023-01-06 07:01:45.263 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xC6B3:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-01-06 07:01:47.076 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x2487:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-01-06 07:01:47.879 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xC6B3:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-01-06 07:01:47.975 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x2042:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2023-01-06 07:01:48.086 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xC6B3:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2023-01-06 07:01:48.529 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x2042:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2023-01-06 07:01:48.532 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x2487:1:0x0008]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-01-06 07:01:48.572 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x2487:1:0x0300]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
2023-01-06 07:03:15.611 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x10AB:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2023-01-06 07:03:17.028 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
2023-01-06 07:03:17.463 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x2042:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>')]
2023-01-06 07:03:17.610 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x10AB:1:0x0300]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>')]
2023-01-06 07:03:19.867 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x10AB:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_NO_ACK: 233>'), DeliveryError('Request failed after 5 attempts: <Status.MAC_CHANNEL_ACCESS_FAILURE: 225>')]
2023-01-06 07:03:42.591 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.1.131:5555. TcpTimeoutException: Connecting to 192.168.1.131:5555 timed out (1.0 seconds)
2023-01-06 07:03:47.037 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
2023-01-06 07:04:17.039 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
2023-01-06 07:04:47.041 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
2023-01-06 07:05:03.837 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.1.131:5555. TcpTimeoutException: Connecting to 192.168.1.131:5555 timed out (1.0 seconds)
2023-01-06 07:05:17.049 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'isScreenOn' when rendering '{{ value_json.isScreenOn }}'
