I think I Need a Zigbee hub
Hi I just buy AM43 Blind motor ZIGBEE. I was hopping to set it up through my Xiaomi Gateway ( V3 ) but I’m not able to do it … may be it’s not compatible…
So I’m looking for a Hub for it. since it tuna I could buy the tuya one but I would like to replace my Xiaomi hub too I hate it ( everything is in japanese ) . The issue is I have a lot of temp / motion sensor from xiaomi can I pair them in the tuya hub ?
The best would be a zigbee controller for home assistant ( USB ? ) so I would’nt have a lot of gateway and hub my Home assistant would control everything …
this is the blind I bought :
Bonus : I have xiaomi 3 door sensor that I bought by mistake they are all 3 bluetooth so I can’t pair them with my gateway and Home assistant. maybe if my futur hub could pair them that could be nice too
Have you tried to Pair it with a TuyaAPP on your phone ?
i.e. Tuya Smart, Android ?
In that case you might even be able to ADD it to Homeassistant through Local_Tuya integration, no hub required.
Aqara-M2 hub, support some Xiaomi devices, like Temp / Motion / Door sensors … i have few of both, in Aqara-hub, Connected through Homekit-Controller Integration in HA
I cant add it in tuya app … since it’s zigbee i need a zigbee hub
Upps, sorry, even thou you typed that with BIG, it slipped through my head :slight_smile: … thou for your other Xiaomi devices, take a look at Aqara-M2( Bought in EU ) Xiaomi/Aqara “same same but different” :slight_smile:
PS: Sorry i don’t have any Tuya Zigbee devices, to test, and in Local-Tuya i only have Deltaco and Nedis Wifi devices
It’s not an absolute need to have my device local but i would like to have less hub possible and of possible remove my xiaomi hub
Buy one of the recommended supported adapters:
https://www.zigbee2mqtt.io/guide/adapters/
