I think Z-Wave JS UI keeps crashing my setup?
I am running HAOS Supervised on a Raspberry Pi 3. I was having issues so I wanted to reinstall HAOS with a fresh start.
I backed up my settings from my old install for Z-Wave JS UI.
With the new install, all I have to do is import the settings and re-enter the path where my stick is?
I clicked save and immediately lost connection to Home Assistant. I’m not sure if it is even booting up since it has been 30 minutes and I still cannot connect.
I have no other addons installed.
I have my security keys saved from my old install. I have no long range keys on my old install.
Can I just copy and paste the 4 Security Keys over? Input the path of my usb stick? Click save and all my old devices should show up?
Or do I have to generate random Security Keys (Long Range) ?
I’m stuck trying to figure out how to get my old setup over to my new setup.
Did you ever manage to fix this? I’ve been trying to get zwave to work with a new instal but it always crashes when i hit save.
My setup was not working on my rpi3 due to the kernel bug. I downgraded my version of HA and everything worked fine.
I think I upgraded before the kernel bug was discovered.
