I want some variables to survive my esp 32 completely powering on and off. I saw we can include eeprom library so I tried doing it using lambda. I created a simple code but it has lots of error I don’t even know how to resolve. I have no programming background, I just learn.
esphome:
friendly_name: Floodgate
libraries:
- EEPROM
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "NFbUsURD0HMB2gn/MMM8nHFCOS/lx6naQmfXhKwWJ/E="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-43F658"
password: "BtYZbqTvD8Yz"
captive_portal:
globals:
- id: button
type: int
- id: testint
type: int
switch:
optimistic: True
on_turn_on:
then:
- lambda: |-
id(testint) = 2;
- script.execute: scrip
on_turn_off:
then:
- lambda: |-
id(testint) = 1;
binary_sensor:
script:
then:
- lambda: |-
#include <EEPROM.h>
#define EEPROM_SIZE 12
Serial.begin(115200);
EEPROM.begin(EEPROM_SIZE);
if (id(testint) == 1) {
EEPROM.write(0, 4);
EEPROM.commit();
} else {
EEPROM.write(0, 8);
EEPROM.commit();
The errors I get:
In file included from /config/esphome/esphome-web-43f658.yaml:72:
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h: In lambda function:
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:52:5: error: invalid declaration of member template in local class
template<typename T>
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:61:5: error: invalid declaration of member template in local class
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:88:5: error: invalid declaration of member template in local class
template <class T> T readAll (int address, T &);
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:107:5: error: invalid declaration of member template in local class
template <class T> T writeAll (int address, const T &);
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:118:20: error: 'setup()::<lambda()>::EEPROMClass EEPROM', declared using local type 'setup()::<lambda()>::EEPROMClass', is used but never defined [-fpermissive]
extern EEPROMClass EEPROM;
Compiling /data/esphome-web-43f658/.pioenvs/esphome-web-43f658/lib64d/WiFi/WiFiServer.cpp.o
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h: At global scope:
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:46:10: warning: 'bool setup()::<lambda()>::EEPROMClass::commit()' used but never defined
bool commit();
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:44:10: warning: 'void setup()::<lambda()>::EEPROMClass::write(int, uint8_t)' used but never defined
void write(int address, uint8_t val);
/data/cache/platformio/packages/framework-arduinoespressif32/libraries/EEPROM/src/EEPROM.h:42:10: warning: 'bool setup()::<lambda()>::EEPROMClass::begin(size_t)' used but never defined
bool begin(size_t size);
*** [/data/esphome-web-43f658/.pioenvs/esphome-web-43f658/src/main.cpp.o] Error 1
========================== [FAILED] Took 7.89 seconds ==========================
