So, I have a custom smart meter adapter, which reports the values via MQTT. My sensor is defined like this:
- platform: mqtt
state_topic: '/smartmeter/sensor/low_tariff_energy'
unit_of_measurement: 'Wh'
icon: 'mdi:flash'
device_class: energy
state_class: total_increasing
value_template: '{{ value | int(default=0) }}'
As the decryption code occasionaly has some hiccups, the MQTT sensor sometimes gets strange values - for example, the values come in a sequence like: 230000, 230021, 230048, 4545454545454, 230067
This of course screws the whole statistics. So, I would like to define the value_template in a way, that it disregards the new value (and the previous value reimains), if the new value is f.e. more than 1000 higher or lower than current value. What would I have to add to the value_template to achieve this?
I tried to experiment with example from THIS thread, but I couldn’t make it work - maybe because at the initialization the value is empty (no retain available) and compared to the new value the result is always false?.
Thx in advance for all your inputs.
