ninesky
(chen)
April 26, 2017, 3:10pm
1
I want to use iBeacons to identify me back home, i should write it like this:
#iphone app 位置
zone.home:
track_ios: true
beacon:
uuid: B5B182C7-EAB1-4988-AA99-B5C1517008D9
major: 1
minor: 2
or
#iphone app 位置
zone.home:
track_ios: false
beacon:
major: 1
minor: 2
I also try to setup my ibeacon (simulated on the Pi3), it was working with owntracks fine. Now I want to use it via the ios app but don’t know where/what settings to make for the UUID?
customize where/what? if not a humor, could you please elaborate further?
ninesky
(chen)
April 27, 2017, 12:32pm
5
#iphone app 位置
zone.home:
track_ios: false
beacon:
major: 1
minor: 5834
customize.yaml
robbiet480
(Robbie Trencheny)
April 27, 2017, 11:37pm
6
Check the docs here , @ninesky is right, you need to put the beacon info in your customize
section for zone.home
, otherwise under the zone configuration if for a zone other than zone.home
ninesky
(chen)
April 28, 2017, 3:57am
7
But I have a problem,track_ios: false
my iBeacons not work ,There is no notice in the app
ninesky
(chen)
April 28, 2017, 9:17am
8
Need to set the zone alone ?
in configuration.yaml
add
zone:
- name: 'Drive'
latitude: XXX
longitude: YYY
radius: 100
ninesky
(chen)
April 29, 2017, 12:28am
10
Finally, i set up so iBeacon can be used
#iphone app 位置
zone.home:
track_ios: true
beacon:
major: 1
minor: 5834
Hope i did not do anything wrong
what hardware are you using to track yourself at home?
i guess your phone on one side but on the other side?
