Hello.
I galley with the use of z-wave module. I wanted to know how to do to rename the id? If it’s possible.
I find it not easy to find in the list the entities type: zwave.fibaro_system_fgs211_switch_3kw
it’s easy way that zwave_chauffe_serviette
Any entity that is supported by the entity registry (which z wave does…) can be modified there.
go to the configuration menu on the left side then click on “entity registry”. Find the device there and edit it.
