I have two HA instances, my main one, and then one with mqtt and zigbee2mqtt (so I do implode things that are currently working).
I had a few questions -
Where do I set up what the button does? (short press/long press/double press?).
Where should these be setup? zigbee2mqtt? in HA?
If I want to leave a main HA, and have my zigbee seperate, are two pi’s the best way to do this?
Thanks @francisp! The instructions are very spot on, but was a bit advanced for me, but I did figure out how to do it from the GUI if other people are curious.
In Configuration → Devices → I select my switch, and clicked on the + for automation.
The above instructions are correct too, as they are found in automations.yaml.
