I’d like to control many lights using Home Assistant. I have bought a batch of 9 bulbs from innr, reference RB 265.
https://www.amazon.fr/gp/product/B07SFW356R/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The 1rst bulb has been added without problem:
interview blue box, then the green box. Done. Working !
Then, I wasn’t able to add another bulb to my configuration.
I can’t believe that over 9 bulbs, only one is working properly.
The Zigbee network comprise another band bulb, a humidity sensor, a smart plug.
My setup:
Ordroid N2 (the blue)
System Health
version | core-2021.6.6 |
installation_type | Home Assistant OS |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.9 |
os_name | Linux |
os_version | 5.9.16 |
arch | aarch64 |
timezone | UTC |
Home Assistant Community Store
GitHub API | ok |
Github API Calls Remaining | 5000 |
Installed Version | 1.11.3 |
Stage | startup |
Available Repositories | 842 |
Installed Repositories | 1 |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Home Assistant Supervisor
host_os | Home Assistant OS 6.1 |
update_channel | stable |
supervisor_version | supervisor-2021.06.6 |
docker_version | 20.10.6 |
disk_total | 28.0 GB |
disk_used | 5.8 GB |
healthy | true |
supported | true |
board | odroid-n2 |
supervisor_api | ok |
version_api | ok |
installed_addons | Duck DNS (1.12.5), Mosquitto broker (5.1.1), WireGuard (0.5.1), File editor (5.3.1), Terminal & SSH (9.1.3) |
Lovelace
dashboards | 5 |
resources | 0 |
views | 8 |
mode | storage |
The controller
ZNP = Texas Instruments Z-Stack ZNP protocol: CC253x, CC26x2, CC13x2
by ZHA
https://www.amazon.fr/gp/product/B0843SL7WM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
logs when adding another bulb
2021-06-26 19:28:31 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2021-06-26 19:28:31 DEBUG (MainThread) [zigpy_znp.api] Received command: SYS.Ping.Rsp(Capabilities=<MTCapabilities.APP|UTIL|SAPI|ZDO|AF|SYS: 377>)
2021-06-26 19:28:43 WARNING (MainThread) [zigpy.device] [0x5685] Failed to discover active endpoints
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/zigbee/application.py", line 1306, in _send_zdo_request
response = await self._znp.request_callback_rsp(
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/api.py", line 563, in request_callback_rsp
return await callback_rsp
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.8/site-packages/zigpy/device.py", line 119, in _initialize
status, _, endpoints = await self.zdo.Active_EP_req(
File "/usr/local/lib/python3.8/site-packages/zigpy/util.py", line 110, in retry
r = await func()
File "/usr/local/lib/python3.8/site-packages/zigpy/device.py", line 194, in request
result, msg = await self._application.request(
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/zigbee/application.py", line 637, in request
return await self._send_request(
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/zigbee/application.py", line 1511, in _send_request
response = await self._send_request_raw(
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/zigbee/application.py", line 1345, in _send_request_raw
return await self._send_zdo_request(
File "/usr/local/lib/python3.8/site-packages/async_timeout/__init__.py", line 55, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.8/site-packages/async_timeout/__init__.py", line 92, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
Any idea ?
Should I try another controller ?
Another brand of bulbs ?
Thanks for your help.
