Hi all,
First of all, a big thanks to all you amazing people out there that create and maintain this fantastic product! I’ve been a satisfied user for over two years now. Before HA I used Domoticz, which works good, but is way more techy and less actively updated.
A few weeks ago, I ordered my second RPi4 and did a complete reinstall. With my previous RPi4 install, I started off on the wrong foot and wanted to correct it. It was also a nice opportunity to drop the SD card and boot from an USB SSD drive. This works great BTW as long as you use the 5.x 64bit version.
My first setup had a Conbee II stick, combined with deCONZ and it worked quite well. I made a few mistakes with names (damn you, OCD slight_smile:) but other than that, I liked it. I later learned that there was native support from HA for Zigbee in the form of ZHA. I read a lot of the forums, and decide to walk this path in my new setup. Mainly because I think that in the long run, this will provide the better experience. The open source nature of it, probably giving it also better support for a lot of device. So I bought another Conbee II stick for my ZHA setup and slowly migrated my devices from deCONZ to my new ZHA setup.
I must say that it works basically the same way as deCONZ, but the overall integration seems a bit better. I do have two issues with this setup and I can’t seem to find other references to it in the community. I do find one reference on Github, but honestly I don’t know if it is exactly my problem.
Issue 1:
The main issue I have is that with ZHA the status of my IKEA bulbs isn’t updated. When I turn them off and on with HA (or the IOS app), everything works fine. But when I change the state, no matter if it’s on, off, brightness or color, this isn’t reflected in HA. A lot of automations depend on the state of these bulbs. For now I can tell my wife to use the app, but this isn’t a long lasting solution. So, is this a know problem? If not, how do I report this issue? Or maybe more generic: what do I need to do with this issue?
Issue 2:
This one is way less important, but I’m just curious on how to properly report this. I’ve got two Xiaomi Aqara wall switches (double and single rocker) that work fine. But I’ve also got four YPHIX wall switches. Three on/off and one with about all the options.
I can pair these with ZHA without problems and they appear as:
ZGRC-KEY-007 by Sunricher
and ZGRC-KEY-009 by Sunricher
.The only thing that is reported to HA however, is the battery state. When I go to ‘Developer tools -> Events’ and listen to events, I see a lot of info when I press the buttons. But I don’t have a clue what to do with this info. I think I can manage to use an event in my automation (have to dive into that), although using predefined settings in the GUI would more sustainable.
But my main question is how and where to look for this support and what information to supply.
Just to be complete:
My setup is Supervisor version 243, HassOS 5.1 (64bit) and HA version 0.114.4
Thanks again for all the hard work and I hope my issues are clear.
