So up until version 60 or so I had a fully configured Home Assistant set up working great, etc.
I just don’t have the time to work on it at the moment and would love some help.
Here is my set up.
Pi #1 - Home Assistant running in a virtual environment with Mosquito MQTT Broker
Pi #2 - Pi-Hole
Pi #3 - Smartthings MQTT bridge - This is where the issue is coming from
I am having a lot of trouble getting Smartthings MQTT Bridge installed and talking to the broker. I will pay you $50 if you are able to get this working.
I will give you remote access to make everything easier. For reference here is my previous configuration.
The important parts are the locks and a couple of random switches.
Fixed the typo, still no luck. Nothing is showing in the <> menu.
Maybe it is the MAC Adress. Should it be the docker image address or the physical address?
The SmartThings MQTT Bridge doesn’t use Discovery unfortunately. You have to create the Sensors, Binary Sensors, etc. by hand. Discovery is filed as an issue.
An example of my Multi Sensor for the Open/Close section.
I don’t use HASSio so I’m not sure how much different it is from the Python ENV version but this should get you going in the right direction.
Another thing I’ve found is that if you have your Pi hooked up to WiFi and Ethernet, make a MQTT Device and SmartApp on ST’s end for both the WiFi and Ethernet IPs and MACs. Mine is working flawlessly now. And as @lolouk44 said, keep your money. We’re here to help one another. Pay it forward if this helps.
Alright, so Smartthings is properly talking to the broker now, as when I unlock a door it updates properly on Home Assistant. It doesn’t seem to be working the other way around.
I had the same issue with the bridge and my smart lock, updates from HA wouldn’t be set on ST. What fixed it was modifying the ST bridge config.yml and uncommenting the
# state_read_suffix: state # state_write_suffix: set_state # command_suffix: cmd
Note that this means you have to update all your devices in the configuration.yaml file. If you have sensors, they only have a state, so state topic would be "smartthings/sensor1/state". If you have things like switches, you would need to do the same, but with a command topic "smartthings/switch1/cmd" for actually turning the switches on and off and also a state topic to read status.
Hope this helps. I’ve had everything working great so far. Will eventually just get a z-wave/zigbee dongle and migrate to fully local but for now I’m using ST.
Also to simplify issues with connectivity, I have the MQTT broker running on a docker container in bridge mode (virtual switch) with it’s own local IP, and the ST bridge also running in bridge mode with its own local IP
Just an FYI. I was seeing this same behavior. What ended up fixing it was going into the ST App on your phone, selecting the device, then clicking on the gear. This brings up the properties pane. Click on ‘Set Date Format’ and select US (UK might do the same thing), as by default nothing is checked. As soon as I did this the data started flowing into HA immediately.
Use IP and Mac address of the physical device and not of the docker.
I was also fiddling with it for weeks. In my case it was something else though but I had some problems with the IP and mac too.
