The cc2652p gateway is accessed under homeassistant. The Zha mode is used. The aqara green rice dynamic and static sensors are accessed. The three click operation can be recognized normally. However, there is no three click option operation in automation. Do you need to write your own code to realize automation? How should I operate? I hope the great God will give me directions. Thank you. I am preparing to trigger the specified operation with three strikes. In the log, I can recognize the action of three strikes, but it is not in the automatic operation configuration.
You have to use zha_event data to register the button presses.
Go to the events page in developers tools and listen for those events. You will see data populate there when you press the button.
Then use that data in your automation triggers.
Thank you. Which service should use in the developer mode
click “start listening”.
Push buttons on the device.
you will see like the following:
Then use the trigger type as event with the data for your device from the event data.
example:
automation:
- alias: LC Computer Room Corner Light Relay
- platform: event
event_type: zha_event
event_data:
device_ieee: "00:15:8d:00:02:90:07:23"
command: single
- service: light.toggle
entity_id: light.comp_corner_lamp_1df9
Thank you for your help. I have achieved it. It’s cool.
