A few weeks ago I started with Home Assistant installed on a Raspberry pi 3 and one of the problems I ran into was configuring or installing “i2c” to be able to use certain sensors that require it.
In particular, I am using ESPhome to take data from a WEMOS D1 Mini with a BMP180 sensor that measures temperature and atmospheric pressure.
Mainly use this guide to install i2c for Home Assistant Enable i2c on the Home Assistant Operating System
But then I did not know how to add it to the code to be able to use it for ESP and I searched the blogs a lot without positive results until luckily I found a single example of the code and it worked perfectly.
You only need to add this to your ESP code (ESPHome), change PINs if its necessary.
i2c:
sda: D2
scl: D1
scan: false
I leave you the example of how it is used by me sensorxxx.yalm:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "yourssid"
password: "password"
ap:
ssid: "Temp Exterior Fallback Hotspot"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
i2c:
sda: D2
scl: D1
scan: false
- platform: bmp085
temperature:
name: "Temp Exterior"
pressure:
name: "Presion Exterior"
update_interval: 60s
I hope it works for you
And thanks to @exxamalte for corrections
