Hi. I was trying to add as3935 sensor to my esp devices with esp32 & esp8266.
Every moment, got a problem in i2c scanning with
[16:06:20][C][i2c.arduino:053]: I2C Bus:
[16:06:20][C][i2c.arduino:054]: SDA Pin: GPIO21
[16:06:20][C][i2c.arduino:055]: SCL Pin: GPIO22
[16:06:20][C][i2c.arduino:056]: Frequency: 100000 Hz
[16:06:20][C][i2c.arduino:059]: Recovery: bus successfully recovered
[16:06:20][I][i2c.arduino:069]: Results from i2c bus scan:
[16:06:20][I][i2c.arduino:071]: Found no i2c devices!
So, I found this and thereβs no way to connect i2c devices in 0x01 ~ 0x07 in esphome.
How can I make it possible to communicate i2c devices address 0x03?
Below is my ull logs with VERY_VERBOSE mode.
Using 'COM3' as serial port.
Unexpected error: could not open port 'COM3': PermissionError(13, 'μ‘μΈμ€κ° κ±°λΆλμμ΅λλ€.', None, 5)
[16:06:09]ets Jun 8 2016 00:22:57
[16:06:09]
[16:06:09]rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[16:06:09]configsip: 0, SPIWP:0xee
[16:06:09]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[16:06:09]mode:DIO, clock div:2
[16:06:09]load:0x3fff0018,len:4
[16:06:09]load:0x3fff001c,len:1044
[16:06:09]load:0x40078000,len:8896
[16:06:09]load:0x40080400,len:5828
[16:06:09]entry 0x400806ac
[16:06:10][ 6][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
[16:06:10][I][logger:262]: Log initialized
[16:06:10][VV][esp32.preferences:071]: nvs_get_blob: key: 233825507, len: 4
[16:06:10][C][ota:469]: There have been 0 suspected unsuccessful boot attempts.
[16:06:10][VV][esp32.preferences:040]: s_pending_save: key: 233825507, len: 4
[16:06:10][D][esp32.preferences:114]: Saving 1 preferences to flash...
[16:06:10][VV][esp32.preferences:123]: Checking if NVS data 233825507 has changed
[16:06:10][V][esp32.preferences:126]: sync: key: 233825507, len: 4
[16:06:10][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[16:06:10][I][app:029]: Running through setup()...
[16:06:10][V][app:030]: Sorting components by setup priority...
[16:06:10][I][i2c.arduino:183]: Performing I2C bus recovery
[16:06:10][ 87][I][esp32-hal-i2c.c:75] i2cInit(): Initialising I2C Master: sda=21 scl=22 freq=100000
[16:06:10][V][i2c.arduino:048]: Scanning i2c bus for active devices...
[16:06:10][VV][i2c.arduino:141]: 0x08 TX
[16:06:10][VV][i2c.arduino:167]: TX failed: not acknowledged
[16:06:10][VV][i2c.arduino:141]: 0x09 TX
[16:06:10][VV][i2c.arduino:141]: 0x0A TX
[16:06:10][VV][i2c.arduino:141]: 0x0B TX
[16:06:10][VV][i2c.arduino:141]: 0x0C TX
[16:06:10][VV][i2c.arduino:141]: 0x0D TX
[16:06:10][VV][i2c.arduino:141]: 0x0E TX
[16:06:10][VV][i2c.arduino:141]: 0x0F TX
[16:06:10][VV][i2c.arduino:141]: 0x10 TX
[16:06:10][VV][i2c.arduino:141]: 0x11 TX
[16:06:10][VV][i2c.arduino:141]: 0x12 TX
[16:06:10][VV][i2c.arduino:141]: 0x13 TX
[16:06:10][VV][i2c.arduino:141]: 0x14 TX
[16:06:10][VV][i2c.arduino:141]: 0x15 TX
[16:06:10][VV][i2c.arduino:141]: 0x16 TX
[16:06:10][VV][i2c.arduino:141]: 0x17 TX
[16:06:10][VV][i2c.arduino:141]: 0x18 TX
[16:06:10][VV][i2c.arduino:141]: 0x19 TX
[16:06:10][VV][i2c.arduino:141]: 0x1A TX
[16:06:11][VV][i2c.arduino:141]: 0x1B TX
[16:06:11][VV][i2c.arduino:167]: TX failed: not acknowledged
[16:06:11][VV][i2c.arduino:141]: 0x1C TX
[16:06:11][VV][i2c.arduino:141]: 0x1D TX
[16:06:11][VV][i2c.arduino:141]: 0x1E TX
[16:06:11][VV][i2c.arduino:141]: 0x1F TX
[16:06:11][VV][i2c.arduino:141]: 0x20 TX
[16:06:11][VV][i2c.arduino:141]: 0x21 TX
[16:06:11][VV][i2c.arduino:141]: 0x22 TX
[16:06:11][VV][i2c.arduino:141]: 0x23 TX
[16:06:11][VV][i2c.arduino:141]: 0x24 TX
[16:06:11][VV][i2c.arduino:141]: 0x25 TX
[16:06:11][VV][i2c.arduino:141]: 0x26 TX
[16:06:11][VV][i2c.arduino:141]: 0x27 TX
[16:06:11][VV][i2c.arduino:141]: 0x28 TX
[16:06:11][VV][i2c.arduino:141]: 0x29 TX
[16:06:11][VV][i2c.arduino:141]: 0x2A TX
[16:06:11][VV][i2c.arduino:141]: 0x2B TX
[16:06:11][VV][i2c.arduino:141]: 0x2C TX
[16:06:11][VV][i2c.arduino:141]: 0x2D TX
[16:06:11][VV][i2c.arduino:141]: 0x2E TX
[16:06:11][VV][i2c.arduino:141]: 0x2F TX
[16:06:11][VV][i2c.arduino:141]: 0x30 TX
[16:06:11][VV][i2c.arduino:141]: 0x31 TX
[16:06:11][VV][i2c.arduino:141]: 0x32 TX
[16:06:11][VV][i2c.arduino:141]: 0x33 TX
[16:06:11][VV][i2c.arduino:141]: 0x34 TX
[16:06:11][VV][i2c.arduino:141]: 0x35 TX
[16:06:11][VV][i2c.arduino:141]: 0x36 TX
[16:06:11][VV][i2c.arduino:141]: 0x37 TX
[16:06:11][VV][i2c.arduino:141]: 0x38 TX
[16:06:11][VV][i2c.arduino:141]: 0x39 TX
[16:06:11][VV][i2c.arduino:141]: 0x3A TX
[16:06:11][VV][i2c.arduino:141]: 0x3B TX
[16:06:11][VV][i2c.arduino:141]: 0x3C TX
[16:06:11][VV][i2c.arduino:141]: 0x3D TX
[16:06:12][VV][i2c.arduino:141]: 0x3E TX
[16:06:12][VV][i2c.arduino:167]: TX failed: not acknowledged
[16:06:12][VV][i2c.arduino:141]: 0x3F TX
[16:06:12][VV][i2c.arduino:141]: 0x40 TX
[16:06:12][VV][i2c.arduino:141]: 0x41 TX
[16:06:12][VV][i2c.arduino:141]: 0x42 TX
[16:06:12][VV][i2c.arduino:141]: 0x43 TX
[16:06:12][VV][i2c.arduino:141]: 0x44 TX
[16:06:12][VV][i2c.arduino:141]: 0x45 TX
[16:06:12][VV][i2c.arduino:141]: 0x46 TX
[16:06:12][VV][i2c.arduino:141]: 0x47 TX
[16:06:12][VV][i2c.arduino:141]: 0x48 TX
[16:06:12][VV][i2c.arduino:141]: 0x49 TX
[16:06:12][VV][i2c.arduino:141]: 0x4A TX
[16:06:12][VV][i2c.arduino:141]: 0x4B TX
[16:06:12][VV][i2c.arduino:141]: 0x4C TX
[16:06:12][VV][i2c.arduino:141]: 0x4D TX
[16:06:12][VV][i2c.arduino:141]: 0x4E TX
[16:06:12][VV][i2c.arduino:141]: 0x4F TX
[16:06:12][VV][i2c.arduino:141]: 0x50 TX
[16:06:12][VV][i2c.arduino:141]: 0x51 TX
[16:06:12][VV][i2c.arduino:141]: 0x52 TX
[16:06:12][VV][i2c.arduino:141]: 0x53 TX
[16:06:12][VV][i2c.arduino:141]: 0x54 TX
[16:06:12][VV][i2c.arduino:141]: 0x55 TX
[16:06:12][VV][i2c.arduino:141]: 0x56 TX
[16:06:12][VV][i2c.arduino:141]: 0x57 TX
[16:06:12][VV][i2c.arduino:141]: 0x58 TX
[16:06:12][VV][i2c.arduino:141]: 0x59 TX
[16:06:12][VV][i2c.arduino:141]: 0x5A TX
[16:06:12][VV][i2c.arduino:141]: 0x5B TX
[16:06:12][VV][i2c.arduino:141]: 0x5C TX
[16:06:12][VV][i2c.arduino:141]: 0x5D TX
[16:06:12][VV][i2c.arduino:141]: 0x5E TX
[16:06:12][VV][i2c.arduino:141]: 0x5F TX
[16:06:12][VV][i2c.arduino:141]: 0x60 TX
[16:06:13][VV][i2c.arduino:167]: TX failed: not acknowledged
[16:06:13][VV][i2c.arduino:141]: 0x61 TX
[16:06:13][VV][i2c.arduino:141]: 0x62 TX
[16:06:13][VV][i2c.arduino:141]: 0x63 TX
[16:06:13][VV][i2c.arduino:141]: 0x64 TX
[16:06:13][VV][i2c.arduino:141]: 0x65 TX
[16:06:13][VV][i2c.arduino:141]: 0x66 TX
[16:06:13][VV][i2c.arduino:141]: 0x67 TX
[16:06:13][VV][i2c.arduino:141]: 0x68 TX
[16:06:13][VV][i2c.arduino:141]: 0x69 TX
[16:06:13][VV][i2c.arduino:141]: 0x6A TX
[16:06:13][VV][i2c.arduino:141]: 0x6B TX
[16:06:13][VV][i2c.arduino:141]: 0x6C TX
[16:06:13][VV][i2c.arduino:141]: 0x6D TX
[16:06:13][VV][i2c.arduino:141]: 0x6E TX
[16:06:13][VV][i2c.arduino:141]: 0x6F TX
[16:06:13][VV][i2c.arduino:141]: 0x70 TX
[16:06:13][VV][i2c.arduino:141]: 0x71 TX
[16:06:13][VV][i2c.arduino:141]: 0x72 TX
[16:06:13][VV][i2c.arduino:141]: 0x73 TX
[16:06:13][VV][i2c.arduino:141]: 0x74 TX
[16:06:13][VV][i2c.arduino:141]: 0x75 TX
[16:06:13][VV][i2c.arduino:141]: 0x76 TX
[16:06:13][VV][i2c.arduino:141]: 0x77 TX
[16:06:13][VV][scheduler:063]: set_interval(name='', interval=60000, offset=19613)
[16:06:13][C][as3935:010]: Setting up AS3935...
[16:06:13][C][as3935:013]: IRQ Pin: GPIO14
[16:06:13][V][as3935:070]: Setting indoor to 1
[16:06:13][VV][i2c.arduino:141]: 0x03 TX 00
[16:06:13][VV][i2c.arduino:117]: 0x03 RX 2F
[16:06:13][VV][i2c.arduino:141]: 0x03 TX 0025
[16:06:13][W][as3935_i2c:021]: write_byte failed - increase log level for more details!
[16:06:13][V][as3935:093]: Setting noise level to 2
[16:06:13][VV][i2c.arduino:141]: 0x03 TX 01
[16:06:13][VV][i2c.arduino:141]: 0x03 TX 012F
[16:06:13][V][as3935:081]: Setting watchdog sensitivity to 2
[16:06:13][VV][i2c.arduino:141]: 0x03 TX 0122
[16:06:14][V][as3935:105]: Setting spike rejection to 2
[16:06:14][VV][i2c.arduino:141]: 0x03 TX 02
[16:06:14][VV][i2c.arduino:167]: TX failed: not acknowledged
[16:06:14][E][component:113]: Component as3935 was marked as failed.
[16:06:14][W][as3935_i2c:013]: read_byte failed - increase log level for more details!
[16:06:14][V][as3935:116]: Setting lightning threshold to 1
[16:06:14][V][as3935:137]: Setting mask disturber to 0
[16:06:14][VV][i2c.arduino:141]: 0x03 TX 03
[16:06:14][V][as3935:149]: Setting div ratio to 0
[16:06:14][V][as3935:173]: Setting tune cap to 0 pF
[16:06:14][VV][i2c.arduino:141]: 0x03 TX 08
[16:06:14][C][wifi:038]: Setting up WiFi...
[16:06:14][C][wifi:039]: Local MAC: 30:AE:A4:99:17:F4
[16:06:14][V][esp32.preferences:059]: nvs_get_blob('835244400'): ESP_ERR_NVS_NOT_FOUND - the key might not be set yet
[16:06:14][V][wifi_esp32:039]: Enabling STA.
[16:06:14][ 1396][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
[16:06:14][V][wifi_esp32:454]: Event: WiFi ready
[16:06:14][ 1492][V][WiFiGeneric.cpp:338] _arduino_event_cb(): STA Started
[16:06:14][ 1492][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 2 - STA_START
[16:06:14][V][wifi_esp32:469]: Event: WiFi STA start
[16:06:17][ 7214][V][WiFiGeneric.cpp:381] _arduino_event_cb(): SCAN Done: ID: 128, Status: 0, Results: 5
[16:06:17][ 7215][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 1 - SCAN_DONE
[16:06:17][V][wifi_esp32:463]: Event: WiFi Scan Done status=0 number=5 scan_id=128
[16:06:17][D][wifi:402]: Found networks:
[16:06:17][I][wifi:446]: - 'Sinri' (FA:92:BF:C1:B2:13) ββββ
[16:06:17][D][wifi:447]: Channel: 1
[16:06:17][D][wifi:448]: RSSI: -81 dB
[16:06:17][D][wifi:451]: - 'Cisco_C2K_2Ghz' (F4:92:BF:C1:B2:13) ββββ
[16:06:17][D][wifi:451]: - '' (06:92:BF:C1:B2:13) ββββ
[16:06:17][D][wifi:451]: - '1234' (FE:92:BF:C1:B2:13) ββββ
[16:06:17][D][wifi:451]: - '' (02:92:BF:C1:B2:13) ββββ
[16:06:17][I][wifi:258]: WiFi Connecting to 'Sinri'...
[16:06:17][V][wifi:260]: Connection Params:
[16:06:17][V][wifi:261]: SSID: 'Sinri'
[16:06:17][V][wifi:264]: BSSID: FA:92:BF:C1:B2:13
[16:06:17][V][wifi:284]: Password: 'qdadada50--'
[16:06:17][V][wifi:289]: Channel: 1
[16:06:17][V][wifi:298]: Using DHCP IP
[16:06:17][V][wifi:300]: Hidden: NO
[16:06:18][ 8005][V][WiFiGeneric.cpp:353] _arduino_event_cb(): STA Connected: SSID: Sinri, BSSID: fa:92:bf:c1:b2:13, Channel: 1, Auth: WPA2_PSK
[16:06:18][ 8006][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 4 - STA_CONNECTED
[16:06:18][V][wifi_esp32:487]: Event: Connected ssid='Sinri' bssid=FA:92:BF:C1:B2:13 channel=1, authmode=WPA2 PSK
[16:06:19][ 9480][V][WiFiGeneric.cpp:367] _arduino_event_cb(): STA Got New IP:192.168.10.105
[16:06:19][ 9481][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 7 - STA_GOT_IP
[16:06:19][ 9484][D][WiFiGeneric.cpp:991] _eventCallback(): STA IP: 192.168.10.105, MASK: 255.255.255.0, GW: 192.168.10.1
[16:06:19][V][wifi_esp32:546]: Event: Got IP static_ip=192.168.10.105 gateway=192.168.10.1
[16:06:19][I][app:062]: setup() finished successfully!
[16:06:19][I][app:102]: ESPHome version 2023.5.5 compiled on Jun 18 2023, 15:24:19
[16:06:19][C][wifi:505]: WiFi:
[16:06:19][C][wifi:363]: Local MAC: 30:AE:A4:99:17:F4
[16:06:19][C][wifi:364]: SSID: 'Sinri'
[16:06:19][C][wifi:365]: IP Address: 192.168.10.105
[16:06:19][C][wifi:367]: BSSID: FA:92:BF:C1:B2:13
[16:06:19][C][wifi:368]: Hostname: 'esp32-lightning'
[16:06:19][C][wifi:370]: Signal strength: -82 dB ββββ
[16:06:19][V][wifi:372]: Priority: 0.0
[16:06:19][C][wifi:374]: Channel: 1
[16:06:19][C][wifi:375]: Subnet: 255.255.255.0
[16:06:19][C][wifi:376]: Gateway: 192.168.10.1
[16:06:19][C][wifi:377]: DNS1: 192.168.10.1
[16:06:19][C][wifi:378]: DNS2: 0.0.0.0
[16:06:19][C][logger:301]: Logger:
[16:06:19][C][logger:302]: Level: VERY_VERBOSE
[16:06:19][C][logger:303]: Log Baud Rate: 115200
[16:06:20][C][logger:305]: Hardware UART: UART0
[16:06:20][C][as3935:027]: AS3935:
[16:06:20][C][as3935:028]: Interrupt Pin: GPIO14
[16:06:20][C][as3935:030]: Thunder alert 'Storm Alert'
[16:06:20][C][as3935:033]: Distance 'Distance Storm'
[16:06:20][C][as3935:033]: State Class: ''
[16:06:20][C][as3935:033]: Unit of Measurement: 'km'
[16:06:20][C][as3935:033]: Accuracy Decimals: 1
[16:06:20][C][as3935:033]: Icon: 'mdi:signal'
[16:06:20][C][as3935:034]: Lightning energy 'Lightning Energy'
[16:06:20][C][as3935:034]: State Class: ''
[16:06:20][C][as3935:034]: Unit of Measurement: ''
[16:06:20][C][as3935:034]: Accuracy Decimals: 1
[16:06:20][C][as3935:034]: Icon: 'mdi:flash'
[16:06:20][C][as3935_i2c:040]: Address: 0x03
[16:06:20][C][captive_portal:088]: Captive Portal:
[16:06:20][C][mdns:108]: mDNS:
[16:06:20][C][mdns:109]: Hostname: esp32-lightning
[16:06:20][V][mdns:110]: Services:
[16:06:20][V][mdns:112]: - _esphomelib, _tcp, 6053
[16:06:20][V][mdns:114]: TXT: friendly_name = esp32-lightning
[16:06:20][V][mdns:114]: TXT: version = 2023.5.5
[16:06:20][V][mdns:114]: TXT: mac = 30aea49917f4
[16:06:20][V][mdns:114]: TXT: platform = ESP32
[16:06:20][V][mdns:114]: TXT: board = esp32dev
[16:06:20][V][mdns:114]: TXT: network = wifi
[16:06:20][C][ota:093]: Over-The-Air Updates:
[16:06:20][C][ota:094]: Address: esp32-lightning.local:3232
[16:06:20][C][ota:097]: Using Password.
[16:06:20][C][api:138]: API Server:
[16:06:20][C][api:139]: Address: esp32-lightning.local:6053
[16:06:20][C][api:141]: Using noise encryption: YES
[16:06:21][D][api:102]: Accepted 192.168.10.179
[16:06:21][VV][api.socket:696]: 192.168.10.179: Handshake complete!
[16:06:21][VV][api.service:476]: on_hello_request: HelloRequest {
[16:06:21] client_info: 'ESPHome Logs 2023.5.5'
[16:06:21] api_version_major: 1
[16:06:21] api_version_minor: 7
[16:06:21]}
[16:06:21][V][api.connection:941]: Hello from client: 'ESPHome Logs 2023.5.5 (192.168.10.179)' | API Version 1.7
[16:06:21][VV][api.service:013]: send_hello_response: HelloResponse {
[16:06:21] api_version_minor: 8
[16:06:21] server_info: 'esp32-lightning (esphome v2023.5.5)'
[16:06:21] name: 'esp32-lightning'
[16:06:21]}
[16:06:21][VV][api.service:485]: on_connect_request: ConnectRequest {
[16:06:21] password: ''
[16:06:21]}
[16:06:21][D][api.connection:959]: ESPHome Logs 2023.5.5 (192.168.10.179): Connected successfully
[16:06:21][VV][api.service:019]: send_connect_response: ConnectResponse {
[16:06:21] invalid_password: NO
[16:06:21]}
[16:06:21][VV][api.service:557]: on_subscribe_logs_request: SubscribeLogsRequest {
[16:06:22] level: LOG_LEVEL_VERY_VERBOSE
[16:06:22] dump_config: NO
[16:06:22]}
