elik745i
(El Nur)
May 21, 2023, 9:46am
1
Hi there, I’m trying to get two MAX98357A boards to work in stereo mode using latest ESPHome on ESP32 (devkit1). However regardless of using stereo mode argument in the code, sound from both speakers work in mono regime.
status_led:
pin:
number: GPIO2
inverted: true
i2s_audio:
- id: i2s_out
i2s_lrclk_pin: GPIO14
i2s_bclk_pin: GPIO27
- id: i2s_in
i2s_lrclk_pin: GPIO13
i2s_bclk_pin: GPIO12
media_player:
- platform: i2s_audio
name: ESPHome I2S Media Player
dac_type: external
i2s_audio_id: i2s_out
i2s_dout_pin: GPIO25
mode: stereo
# Example configuration entry
microphone:
i2s_audio_id: i2s_in
i2s_din_pin: GPIO26
adc_type: external
pdm: false
voice_assistant:
microphone: mic_i2s
I have used the following diagram to hook DAC modules (mine hooked to different pins):
Can someone holp to sort this out?
Arh
May 21, 2023, 12:14pm
2
I don’t know much if anything about these boards so I could be very wrong.
But the wiring diagram shows both amp boards wired to exactly the same signal. Do you not have to toggle a pin on the board for left or right channel?
elik745i
(El Nur)
May 21, 2023, 12:21pm
3
there is no such a code in ESPHome to separate left and right channels with external DAC unfortunatelly. Stereo signal carry signal separation so LRCLK can understand which channel it should decode and play.
As far as I understood, the problem might be with ESPHome itself. I might be wrong.
UPDATE: Figured out stereo output. Problem was in MAX98357A configuration. By default it is configured to mix outputs using 1M resistor (to VDD) so to configure it to left and right channels, SD needs to be pulled-up to VDD with jumper (0 Ohms) that is going to be LEFT channel and with 370-470K resistor to VDD to output Right channel.
All perfect now.
By the way I get really nice sound quality despite this is only class D amplifier.
and here is my little project printed for stereo WiFi player ))
and here is my code:
captive_portal:
status_led:
pin:
number: GPIO2
inverted: true
i2s_audio:
- id: i2s_out
- id: i2s_in
i2s_lrclk_pin: GPIO32 #ws
i2s_bclk_pin: GPIO33 #sck
# LR to be grounded
media_player:
dac_type: external
mode: stereo
microphone:
i2s_din_pin: GPIO26 #sd
adc_type: external
pdm: false
voice_assistant:
microphone: mic_i2s
Brano69
(Brano)
April 24, 2024, 10:28am
4
Would you be kind enough to share the connection diagram of the components of your I2S ESP Stereo… Thank you!
@elik745i those speakers look massive… Is the amp able to drive them nicely?
What are the specs of the speakers?
mcarty
(Arturo)
May 5, 2024, 11:07pm
6
I am also curious about those speakers.
Can you post ohms and watts?
elik745i
(El Nur)
June 20, 2024, 5:41pm
7
Those were for testing purpose only! For sure to drive those you would need AMP
HomeVi
(Vito)
September 15, 2024, 8:35pm
8
Great work! Would you be kind enough to share the connection diagram of the components of your I2S ESP Stereo… Thank you!
sri4iot
(Sri R)
September 20, 2024, 3:19am
9
Are you using the board mentioned here . I am trying to implement something similar with esp.
sri4iot
(Sri R)
September 25, 2024, 8:52am
10
The connection between DAC and esp32 chip is as given below. Please refer to my other post where I have used different DAC but the result is same. I am getting the stereo quality output.
esp32 --------- UDA1334A
VIN ------------- VIN
GND ----------- GND
GPIO25 ------- DIN
GPIO26 ------- WSEL
GPIO27 ------- BCLK
Eimer
(Eimer)
October 20, 2024, 11:09am
12
Did you find a way to set the volume via I2S (i.e., via software or config)?
hiteshkher
(hitesh kher)
November 27, 2024, 2:17pm
13
Nice Details , can you share hardware wiring photos, if you do good for me, Thank you.
elik745i
(El Nur)
February 8, 2025, 9:13am
14
For Voice Assistant to work with the device, as ESP32 chip is not that powerful, it gets laggy, to mitigate it, we need to stop media player before we communicate to it. I came up with this code so far:
esphome:
friendly_name: Stereo_Notifier
on_boot:
priority: 600 # Ensure this runs after other setup steps
then:
- media_player.volume_set:
volume: 0.2
- logger.log: "System initialized, I2S audio ready."
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "your key"
ota:
- platform: esphome
password: "your pass"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Stereo-Notifier Fallback Hotspot"
password: "your passwd"
captive_portal:
status_led:
pin:
number: GPIO2
inverted: true
i2s_audio:
- id: i2s_out
- id: i2s_in
# I2S media player configuration (stereo mode)
media_player:
dac_type: external
mode: stereo
# I2S microphone configuration
microphone:
adc_type: external
pdm: false
channel: right
bits_per_sample: 16bit
i2s_din_pin: GPIO26
- platform: internal_temperature
name: "Internal Temperature"
voice_assistant:
microphone: mic_i2s
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 4.0
use_wake_word: false
media_player: media_player_speaker
switch:
- platform: restart
name: "Stereo Speaker Restart"
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
- voice_assistant.start_continuous
on_turn_off:
- voice_assistant.stop
- lambda: id(va).set_use_wake_word(false);
binary_sensor:
- platform: status
name: API Connection
filters:
- delayed_on: 1s
on_press:
- if:
condition:
switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
on_release:
- if:
condition:
then:
- voice_assistant.stop:
# Automation to pause and resume voice assistant based on media playback
interval:
- interval: 10s
then:
- if:
condition:
- media_player.is_playing:
then:
- if:
condition:
- switch.is_on: use_wake_word
then:
- logger.log: "Pausing voice assistant due to media playback."
else:
- if:
condition:
- not:
then:
- if:
condition:
then:
- logger.log: "Resuming voice assistant after media playback."
Did you check the datasheet?
Check page 17 Table 5 SD_Mode Control, use one as Left other as Right it will work, unless your audio is mono (both have same data)
