I wired a few Shelly I3s behind some switches in my house. All my other Shelly devices can be triggered/read within Node Red. However I cannot see the events that my I3s trigger.
Found two alternatives, but can be cumbersome,
switch my I3 into MQTT device (but lose Shelly Cloud functionality)
With automate within HA, I can see the different triggers (clicks on switch) and turn them into a HA event. (which is a lot of effort)
any update on this? How have you solved the problem?
If I configure the shelly button type as toggle switch I get the state of the shelly i3 in NodeRed with the events: state and current state nodes, but if I momentary button type I can not select it in NodeRed. I only need feedback if the momentary button in pressed or not (no events lik single press, double press…) - this will be done by GitHub - bartbutenaers/node-red-contrib-button-events: A Node-RED node to send events based on button actions
thank you for the information As I can see you are using the events of the Shelly i3, which would work, but I would like to get not the events (single click, double click…) but just the state of the momentary switch (pressed/not pressed). But i can not find a solution for this issue. I only get the state if I select atoggle switch… would this maybe work if I use MQTT?
I think I will write the shelly support if they have an idea…
