IBA Tunnelflight Integration (Indoor Skydiving)
IBA Tunnelflight Integration for Home Assistant
A custom integration that connects to the International Bodyflight Association (IBA) website and displays your indoor skydiving data in Home Assistant.
Features
  • Display your IBA membership status
  • Show flight skills (Static, Dynamic, and Formation levels)
  • Track total flight time
  • Monitor payment and currency expiry dates
  • Support for multiple IBA accounts in one Home Assistant instance
  • Log flight time directly from Home Assistant
  • Search for tunnels using a dynamic database
Installation
HACS Installation (Recommended)
  1. Make sure you have HACS installed
  2. Add this repository as a custom repository in HACS:
    • Go to HACS → Integrations
    • Click the three dots in the top right corner
    • Select “Custom repositories”
    • Add the URL: https://github.com/B-Hartley/tunnelflight
    • Select “Integration” as the category
  3. Click “Download” on the IBA Tunnelflight integration
  4. Restart Home Assistant
Manual Installation
  1. Create the directory structure in your Home Assistant configuration directory:
    custom_components/tunnelflight/translations/
  2. Copy these files to the tunnelflight directory:
    • __init__.py
    • api.py
    • binary_sensor.py
    • config_flow.py
    • const.py
    • logbook_service.py
    • manifest.json
    • sensor.py
    • services.yaml
    • And en.json to the translations subdirectory
  3. Restart Home Assistant
Configuration
  1. Go to SettingsDevices & ServicesAdd Integration
  2. Search for “IBA Tunnelflight” and follow the setup process
  3. Enter your IBA username and password
  4. Optionally, provide a custom name for the integration
The integration verifies your credentials before completing the setup.
Available Entities
Each IBA account will create the following entities:
Sensors
  • sensor.iba_[username]: Main sensor showing membership status
  • sensor.iba_[username]_total_flight_time: Total flight time
  • sensor.iba_[username]_last_flight: Date of last flight
  • sensor.iba_[username]_static_level: Static flying level
  • sensor.iba_[username]_dynamic_level: Dynamic flying level
  • sensor.iba_[username]_formation_level: Formation flying level
Binary Sensors
  • binary_sensor.iba_[username]_flyer_currency: Flyer currency status with expiry date
  • binary_sensor.iba_[username]_payment_status: Payment status with expiry date
Services
The integration provides services that allow you to interact with your IBA account.
tunnelflight.log_flight_time
This service allows you to add new flight time entries to your Tunnelflight logbook directly from Home Assistant.
Parameters
Parameter Type Required Description
tunnel_id int Yes The ID of the tunnel where you flew
time int Yes Flight time in minutes (1-120)
comment string No Optional comment for the entry
entry_date datetime No The date of the flight (defaults to current time)
Example Service Call
service: tunnelflight.log_flight_time
  tunnel_id: 248  # Basingstoke iFLY
  time: 10  # 10 minutes of flight time
  comment: "Great session with Coach John"
  # entry_date is optional, defaults to current time
tunnelflight.find_tunnels
This service allows you to search for wind tunnels by name, city, or country. The results will be displayed as a persistent notification in Home Assistant.
Parameters
search_term string No Search term to look for in tunnel name or city
country string No Filter results by country
list_countries boolean No Set to true to list all available countries with tunnels
service: tunnelflight.find_tunnels
  search_term: "manchester"
  country: "united kingdom"
To see a list of all available countries with wind tunnels:
  list_countries: true
If you don't provide any parameters, the service will list all available tunnels.
## Finding Tunnel IDs
Instead of using hard-coded tunnel IDs, you can use the `tunnelflight.find_tunnels` service to dynamically search for tunnel information. This service will display a notification with matching tunnels and their IDs.
Example:
```yaml
This will show a notification with details about Manchester iFLY, including its ID that you can use in the log_flight_time service.
Some common tunnel IDs for reference:
  • 225: Milton Keynes iFLY
  • 242: Manchester iFLY
  • 248: Basingstoke iFLY
  • 245: Seattle iFLY
  • 264: Downunder iFLY (Australia)
  • 250: Toronto - Oakville iFLY
Skill Levels and Attributes
The skill sensors provide rich data about your IBA certification levels:
Attribute Description
state The numeric level (0, 1, 2, etc.)
status Status: “Passed”, “Not Passed”, or “Pending”
raw_value Raw value from IBA website (e.g., “Yes”, “No”, “Level 2”)
pending Whether the certification is pending (true/false)
level1 Status of the prerequisite Level1 certification
level1_pending Whether Level1 is pending
Dashboard Examples
Basic Card
type: entities
title: Indoor Skydiving
entities:
  - entity: sensor.iba_username
  - entity: sensor.iba_username_total_flight_time
    name: Total Flight Time
  - entity: sensor.iba_username_last_flight
  - entity: binary_sensor.iba_username_flyer_currency
    secondary_info: attribute
    secondary_info_attribute: expiry_date
  - entity: binary_sensor.iba_username_payment_status
Skills Card
type: glance
title: Flying Skills
entities:
  - entity: sensor.iba_username_static_level
    icon: mdi:alpha-s-circle
  - entity: sensor.iba_username_dynamic_level
    icon: mdi:alpha-d-circle
  - entity: sensor.iba_username_formation_level
    icon: mdi:alpha-f-circle
Log Flight Time Card
type: entities
title: Log Flight Time
entities:
  - entity: input_select.tunnelflight_tunnel
  - entity: input_number.tunnelflight_flight_time
  - entity: input_text.tunnelflight_comment
  - type: button
    name: Log Flight Time
    tap_action:
      action: call-service
      service_data:
        tunnel_id: >-
          {% set tunnel = states('input_select.tunnelflight_tunnel') %}
          {% if '(' in tunnel and ')' in tunnel %}
            {{ tunnel.split('(')[1].split(')')[0] }}
          {% else %}
            248
          {% endif %}
        time: "{{ states('input_number.tunnelflight_flight_time') | int }}"
        comment: "{{ states('input_text.tunnelflight_comment') }}"
Required configuration for the card above:
# Add to your configuration.yaml
input_select:
  tunnelflight_tunnel:
    options:
      - Basingstoke iFLY (248)
      - Manchester iFLY (242)
      - Milton Keynes iFLY (225)
    initial: Basingstoke iFLY (248)
    icon: mdi:fan
input_number:
  tunnelflight_flight_time:
    initial: 10
    min: 1
    max: 120
    step: 1
    mode: slider
    unit_of_measurement: min
input_text:
  tunnelflight_comment:
    initial: ''
Conditional Card with Skill Status
type: conditional
conditions:
    state_not: "0"
card:
  type: markdown
  content: >
    ## Static Level {{ states('sensor.iba_username_static_level') }}
    Status: {{ state_attr('sensor.iba_username_static_level', 'status') }}
Automations
Payment Expiry Notification
- alias: IBA Payment Expiring Soon
    - platform: numeric_state
      entity_id: binary_sensor.iba_username_payment_status
      attribute: days_remaining
      below: 30
    - service: notify.mobile_app
        title: "IBA Payment Expiring Soon"
        message: "Your IBA payment expires in {{ state_attr('binary_sensor.iba_username_payment_status', 'days_remaining') }} days ({{ state_attr('binary_sensor.iba_username_payment_status', 'expiry_date') }})"
Currency Expiry Notification
- alias: IBA Currency Expiring Soon
      entity_id: binary_sensor.iba_username_flyer_currency
      below: 30
        title: "IBA Currency Expiring Soon"
        message: "Your IBA currency expires in {{ state_attr('binary_sensor.iba_username_flyer_currency', 'days_remaining') }} days ({{ state_attr('binary_sensor.iba_username_flyer_currency', 'expiry_date') }})"
Log Weekly Flight Time
- alias: Log Weekly Tunnel Session
    - platform: time
      at: "20:00:00"
  condition:
    - condition: time
      weekday:
        - fri
    - service: tunnelflight.log_flight_time
        time: 30
        comment: "Weekly training session"
Find Tunnel and Log Time
- alias: Find and Log Tunnel Time
  sequence:
    - service: tunnelflight.find_tunnels
        search_term: "{{ search_term }}"
    - delay:
        seconds: 5
        tunnel_id: "{{ tunnel_id }}"
        time: "{{ time }}"
        comment: "{{ comment }}"
Multiple Accounts
The integration supports multiple IBA accounts. Each account creates its own set of entities with the username included in the entity ID to avoid conflicts.
For example, if you have accounts for “bruceh” and “sarahh”, you’ll get:
  • sensor.iba_bruceh_total_flight_time
  • sensor.iba_sarahh_total_flight_time
Troubleshooting
Enable Debug Logging
Add this to your configuration.yaml file:
logger:
  default: info
  logs:
    custom_components.tunnelflight: debug
Common Issues
  • Authentication errors: Verify your IBA username and password
  • Missing data: The integration may not be able to find some data on the IBA website
  • Incorrect skill levels: Use the raw_value attribute to see what the IBA website is reporting
  • Service errors: If you get errors using services, check the logs for details
Privacy and Security
This integration stores your IBA credentials in Home Assistant’s configuration and uses them to log in to the IBA website. Your credentials are not sent anywhere else.
Credits
This integration is an independent community project and is not affiliated with or endorsed by the International Bodyflight Association.
I had a go at indoor skydiving. Now I know I won’t be blown away in a hurricane.
I never knew such a thing existed. I am blown away.
