iCloud (device tracker) error after update to 94.x
Since the upgrade to 94.x) I get this error multiple times in the log:
Error logging into iCloud Service: (‘Invalid email/password combination.’, PyiCloudAPIResponseError(‘Failed to validate the credentials from cookie’))
However the username/password and the device tracker config have not changed. I tried deleting the icloud folder and restarting HA multiple times.
Anyone?
I’m seeing this too (sorry - not so much of a resolution :slight_smile: ) I’ve seen it since roughly midnight last night.
I’ve validated the creds are correct by logging into icloud.com and all good :slight_smile:
Can confirm the issue as well.
Hassio: 0.94
Icloud3: PreRelease 1.0.4.a (as well older version)
2019-06-11 16:11:19 ERROR (SyncWorker_6) [pyicloud.base.http] Failed to validate the credentials from cookie
2019-06-11 16:11:19 ERROR (SyncWorker_6) [custom_components.icloud3.device_tracker] Error logging into iCloud Service: (‘Invalid email/password combination.’, PyiCloudAPIResponseError(‘Failed to validate the credentials from cookie’))
2019-06-11 16:11:19 ERROR (SyncWorker_6) [custom_components.icloud3.device_tracker] No ICLOUD_ACCOUNTS added
Credentials are confirmed by logging in to iCloud.
Yes I am seeing this as well after the upgrade to 0.94.x
Ok, looks like a bug. Filed one here: https://github.com/home-assistant/home-assistant/issues/24476
same issue here - maybe thats the sign I needed to move to owntracks…
It seems it’s nothing to do with HA but apple seems to have changed something.
I have the same issue in my logs :frowning:
same issue on my end.
Confirmed here as well. Interestingly enough none of my devices seem to be affected by the issue. Tracking continues to work.
I have the same issue in my logs too…
Same thing. As I posted on Github, this method still works and I’m switching to it:
Any news? I’m still facing this issue…
same issue here.
same issue
I’m still having this issue after upgrading to 95.x
Did anyone solved it?
same issue
I have the same issue.
same issue here
('Invalid email/password combination.', PyiCloudAPIResponseError('Failed to validate the credentials from cookie'))
