I figured it out!
HA uses the pyicloud library.
When the icloud
platform of the device_tracker
component starts , it calls the devices
property of the PyiCloudService
class imported from pyicloud
library.
The devices
property returns the list of all the devices associated with the account in question, including all the previous old devices.
The platform first lists all devices and only later checks which device is the active one.
For instance, every time I’ve upgraded to a new device, I always changed the name of the device:
tomer's iphone4
tomer's iphone5s
tomer's iphone6s
So I have no problems…
My wife on the other end, never does that, so all of her devices are named hava's iphone
So that means that every time the device_tracker
starts, it tries to list multiple devices with the same name, hence the error.
To fix that, I’ve copied the icloud
platform from HA’s github and added an if statement
validating the device’s statusCode is 200
, the old devices always return 205
I’ve placed the file in /config/custom_components/device_tracker/icloud.py
so HA overwrites the original component with the custom one.
That fixed it for me.
I’ll test it a bit more and eventually try to add a PR for ha with the fix.
For now, here is the “fixed” icloud
platform, all I did is add the if statements
in line 192 and line 399:
Platform that supports scanning iCloud.
For more details about this platform, please refer to the documentation at
https://home-assistant.io/components/device_tracker.icloud/
import logging
import random
import os
import voluptuous as vol
from homeassistant.const import CONF_USERNAME, CONF_PASSWORD
from homeassistant.components.device_tracker import (
PLATFORM_SCHEMA, DOMAIN, ATTR_ATTRIBUTES, ENTITY_ID_FORMAT, DeviceScanner)
from homeassistant.components.zone import active_zone
from homeassistant.helpers.event import track_utc_time_change
import homeassistant.helpers.config_validation as cv
from homeassistant.util import slugify
import homeassistant.util.dt as dt_util
from homeassistant.util.location import distance
_LOGGER = logging.getLogger(__name__)
REQUIREMENTS = ['pyicloud==0.9.1']
CONF_IGNORED_DEVICES = 'ignored_devices'
CONF_ACCOUNTNAME = 'account_name'
# entity attributes
ATTR_ACCOUNTNAME = 'account_name'
ATTR_INTERVAL = 'interval'
ATTR_DEVICENAME = 'device_name'
ATTR_BATTERY = 'battery'
ATTR_DISTANCE = 'distance'
ATTR_DEVICESTATUS = 'device_status'
ATTR_LOWPOWERMODE = 'low_power_mode'
ATTR_BATTERYSTATUS = 'battery_status'
ICLOUDTRACKERS = {}
_CONFIGURING = {}
DEVICESTATUSSET = ['features', 'maxMsgChar', 'darkWake', 'fmlyShare',
'deviceStatus', 'remoteLock', 'activationLocked',
'deviceClass', 'id', 'deviceModel', 'rawDeviceModel',
'passcodeLength', 'canWipeAfterLock', 'trackingInfo',
'location', 'msg', 'batteryLevel', 'remoteWipe',
'thisDevice', 'snd', 'prsId', 'wipeInProgress',
'lowPowerMode', 'lostModeEnabled', 'isLocating',
'lostModeCapable', 'mesg', 'name', 'batteryStatus',
'lockedTimestamp', 'lostTimestamp', 'locationCapable',
'deviceDisplayName', 'lostDevice', 'deviceColor',
'wipedTimestamp', 'modelDisplayName', 'locationEnabled',
'isMac', 'locFoundEnabled']
DEVICESTATUSCODES = {
'200': 'online',
'201': 'offline',
'203': 'pending',
'204': 'unregistered',
SERVICE_SCHEMA = vol.Schema({
vol.Optional(ATTR_ACCOUNTNAME): vol.All(cv.ensure_list, [cv.slugify]),
vol.Optional(ATTR_DEVICENAME): cv.slugify,
vol.Optional(ATTR_INTERVAL): cv.positive_int,
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_USERNAME): cv.string,
vol.Required(CONF_PASSWORD): cv.string,
vol.Optional(ATTR_ACCOUNTNAME): cv.slugify,
def setup_scanner(hass, config: dict, see, discovery_info=None):
"""Set up the iCloud Scanner."""
username = config.get(CONF_USERNAME)
password = config.get(CONF_PASSWORD)
account = config.get(CONF_ACCOUNTNAME, slugify(username.partition('@')[0]))
icloudaccount = Icloud(hass, username, password, account, see)
if icloudaccount.api is not None:
ICLOUDTRACKERS[account] = icloudaccount
else:
_LOGGER.error("No ICLOUDTRACKERS added")
return False
def lost_iphone(call):
"""Call the lost iPhone function if the device is found."""
accounts = call.data.get(ATTR_ACCOUNTNAME, ICLOUDTRACKERS)
devicename = call.data.get(ATTR_DEVICENAME)
for account in accounts:
if account in ICLOUDTRACKERS:
ICLOUDTRACKERS[account].lost_iphone(devicename)
hass.services.register(DOMAIN, 'icloud_lost_iphone', lost_iphone,
schema=SERVICE_SCHEMA)
def update_icloud(call):
"""Call the update function of an iCloud account."""
ICLOUDTRACKERS[account].update_icloud(devicename)
hass.services.register(DOMAIN, 'icloud_update', update_icloud,
def reset_account_icloud(call):
"""Reset an iCloud account."""
ICLOUDTRACKERS[account].reset_account_icloud()
hass.services.register(DOMAIN, 'icloud_reset_account',
reset_account_icloud, schema=SERVICE_SCHEMA)
def setinterval(call):
interval = call.data.get(ATTR_INTERVAL)
ICLOUDTRACKERS[account].setinterval(interval, devicename)
hass.services.register(DOMAIN, 'icloud_set_interval', setinterval,
# Tells the bootstrapper that the component was successfully initialized
return True
class Icloud(DeviceScanner):
"""Representation of an iCloud account."""
def __init__(self, hass, username, password, name, see):
"""Initialize an iCloud account."""
self.hass = hass
self.username = username
self.password = password
self.api = None
self.accountname = name
self.devices = {}
self.seen_devices = {}
self._overridestates = {}
self._intervals = {}
self.see = see
self._trusted_device = None
self._verification_code = None
self._attrs = {}
self._attrs[ATTR_ACCOUNTNAME] = name
self.reset_account_icloud()
randomseconds = random.randint(10, 59)
track_utc_time_change(
self.hass, self.keep_alive, second=randomseconds)
def reset_account_icloud(self):
from pyicloud import PyiCloudService
from pyicloud.exceptions import (
PyiCloudFailedLoginException, PyiCloudNoDevicesException)
icloud_dir = self.hass.config.path('icloud')
if not os.path.exists(icloud_dir):
os.makedirs(icloud_dir)
try:
self.api = PyiCloudService(
self.username, self.password,
cookie_directory=icloud_dir,
verify=True)
except PyiCloudFailedLoginException as error:
self.api = None
_LOGGER.error("Error logging into iCloud Service: %s", error)
return
try:
self.devices = {}
for device in self.api.devices:
status = device.status(DEVICESTATUSSET)
'''tomerfi: added status validation to avoid old devices being listed'''
if status['deviceStatus'] in ['200', '201']:
devicename = slugify(status['name'].replace(' ', '', 99))
if devicename in self.devices:
_LOGGER.error('Multiple devices with name: %s', devicename)
continue
self.devices[devicename] = device
self._intervals[devicename] = 1
self._overridestates[devicename] = None
except PyiCloudNoDevicesException:
_LOGGER.error('No iCloud Devices found!')
def icloud_trusted_device_callback(self, callback_data):
"""Handle chosen trusted devices."""
self._trusted_device = int(callback_data.get('trusted_device'))
self._trusted_device = self.api.trusted_devices[self._trusted_device]
if not self.api.send_verification_code(self._trusted_device):
_LOGGER.error("Failed to send verification code")
return
if self.accountname in _CONFIGURING:
request_id = _CONFIGURING.pop(self.accountname)
configurator = self.hass.components.configurator
configurator.request_done(request_id)
# Trigger the next step immediately
self.icloud_need_verification_code()
def icloud_need_trusted_device(self):
"""We need a trusted device."""
return
devicesstring = ''
devices = self.api.trusted_devices
for i, device in enumerate(devices):
devicename = device.get(
'deviceName', 'SMS to %s' % device.get('phoneNumber'))
devicesstring += "{}: {};".format(i, devicename)
_CONFIGURING[self.accountname] = configurator.request_config(
'iCloud {}'.format(self.accountname),
self.icloud_trusted_device_callback,
description=(
'Please choose your trusted device by entering'
' the index from this list: ' + devicesstring),
entity_picture="/static/images/config_icloud.png",
submit_caption='Confirm',
fields=[{'id': 'trusted_device', 'name': 'Trusted Device'}]
def icloud_verification_callback(self, callback_data):
"""Handle the chosen trusted device."""
from pyicloud.exceptions import PyiCloudException
self._verification_code = callback_data.get('code')
try:
if not self.api.validate_verification_code(
self._trusted_device, self._verification_code):
raise PyiCloudException('Unknown failure')
except PyiCloudException as error:
# Reset to the initial 2FA state to allow the user to retry
_LOGGER.error("Failed to verify verification code: %s", error)
self.icloud_need_trusted_device()
def icloud_need_verification_code(self):
"""Return the verification code."""
return
self.icloud_verification_callback,
description=('Please enter the validation code:'),
fields=[{'id': 'code', 'name': 'code'}]
def keep_alive(self, now):
"""Keep the API alive."""
if self.api is None:
return
if self.api.requires_2fa:
try:
if self._trusted_device is None:
return
if self._verification_code is None:
return
self.api.authenticate()
raise Exception('Unknown failure')
_LOGGER.error("Error setting up 2FA: %s", error)
else:
currentminutes = dt_util.now().hour * 60 + dt_util.now().minute
try:
for devicename in self.devices:
interval = self._intervals.get(devicename, 1)
if ((currentminutes % interval == 0) or
(interval > 10 and
currentminutes % interval in [2, 4])):
self.update_device(devicename)
except ValueError:
_LOGGER.debug("iCloud API returned an error")
def determine_interval(self, devicename, latitude, longitude, battery):
"""Calculate new interval."""
currentzone = active_zone(self.hass, latitude, longitude)
if ((currentzone is not None and
currentzone == self._overridestates.get(devicename)) or
(currentzone is None and
self._overridestates.get(devicename) == 'away')):
return
zones = (self.hass.states.get(entity_id) for entity_id
in sorted(self.hass.states.entity_ids('zone')))
distances = []
for zone_state in zones:
zone_state_lat = zone_state.attributes['latitude']
zone_state_long = zone_state.attributes['longitude']
zone_distance = distance(
latitude, longitude, zone_state_lat, zone_state_long)
distances.append(round(zone_distance / 1000, 1))
if distances:
mindistance = min(distances)
else:
mindistance = None
if currentzone is not None:
self._intervals[devicename] = 30
return
if mindistance is None:
return
# Calculate out how long it would take for the device to drive to the
# nearest zone at 120 km/h:
interval = round(mindistance / 2, 0)
# Never poll more than once per minute
interval = max(interval, 1)
if interval > 180:
# Three hour drive? This is far enough that they might be flying
# home - check every half hour
interval = 30
if battery is not None and battery <= 33 and mindistance > 3:
# Low battery - let's check half as often
interval = interval * 2
self._intervals[devicename] = interval
def update_device(self, devicename):
"""Update the device_tracker entity."""
from pyicloud.exceptions import PyiCloudNoDevicesException
# An entity will not be created by see() when track=false in
# 'known_devices.yaml', but we need to see() it at least once
entity = self.hass.states.get(ENTITY_ID_FORMAT.format(devicename))
if entity is None and devicename in self.seen_devices:
return
attrs = {}
kwargs = {}
return
try:
if str(device) != str(self.devices[devicename]):
continue
dev_id = status['name'].replace(' ', '', 99)
dev_id = slugify(dev_id)
attrs[ATTR_DEVICESTATUS] = DEVICESTATUSCODES.get(
status['deviceStatus'], 'error')
attrs[ATTR_LOWPOWERMODE] = status['lowPowerMode']
attrs[ATTR_BATTERYSTATUS] = status['batteryStatus']
attrs[ATTR_ACCOUNTNAME] = self.accountname
battery = status.get('batteryLevel', 0) * 100
location = status['location']
if location:
self.determine_interval(
devicename, location['latitude'],
location['longitude'], battery)
attrs[ATTR_INTERVAL] = interval
accuracy = location['horizontalAccuracy']
kwargs['dev_id'] = dev_id
kwargs['host_name'] = status['name']
kwargs['gps'] = (location['latitude'],
location['longitude'])
kwargs['battery'] = battery
kwargs['gps_accuracy'] = accuracy
kwargs[ATTR_ATTRIBUTES] = attrs
self.see(**kwargs)
self.seen_devices[devicename] = True
_LOGGER.error("No iCloud Devices found")
def lost_iphone(self, devicename):
return
if devicename is None or device == self.devices[devicename]:
device.play_sound()
def update_icloud(self, devicename=None):
"""Authenticate against iCloud and scan for devices."""
return
try:
if devicename is not None:
self.devices[devicename].location()
else:
_LOGGER.error("devicename %s unknown for account %s",
devicename, self._attrs[ATTR_ACCOUNTNAME])
else:
for device in self.devices:
self.devices[device].location()
def setinterval(self, interval=None, devicename=None):
"""Set the interval of the given devices."""
devs = [devicename] if devicename else self.devices
for device in devs:
devid = '{}.{}'.format(DOMAIN, device)
devicestate = self.hass.states.get(devid)
if interval is not None:
if devicestate is not None:
self._overridestates[device] = active_zone(
self.hass,
float(devicestate.attributes.get('latitude', 0)),
float(devicestate.attributes.get('longitude', 0)))
if self._overridestates[device] is None:
self._overridestates[device] = 'away'
self._intervals[device] = interval
else:
self._overridestates[device] = None
self.update_device(device)
