iCloud integration not supported in UI
I don’t know why I can’t configure the iCloud integration. I have not had any issue with other integrations.
Running in a VM and everything is updated.
Is there a known issue of integrations failing to configure and is there a fix? It seems to be only the iCloud integration as I was able to setup and configure ZHA.
There is no way I can see of setting iCloud up via YAML. The only other option I can see is to use iCloud3 but I try to stay away from third party.
Updated today to 2022.04 and the issue is still happening.
I think I found the issue. Pyicloud had a breaking change in February migrating from pytz.
Migrate from pytz #377
I was pointed to an issue opened a month ago with a similar issue. The person it was assigned to hasn’t had any activity on github since February or the HASS forum since December from what I can see.
Setup failed for icloud after update to 2022.3.X #67845
