Continuing the discussion from 0.32.1 ICloud Lost Device:
This issue from way back when (0.32!) seems to persist… Basically when you call the lost iPhone function all your devices linked to iCloud ring as they should. However you should be able to use “device_name” to restrict the ringing to a specific device. This doesn’t seem to work.
A possible fix (to do with how the code is handling strings) is detailed in the linked thread but not sure if that still applies to the more recent version of the component?
Anyone with knowledge of this able to help/investigate?
Thanks!
