Home Assistant notified me of an available upgrade today, so I went ahead and installed. After upgrading, iCloud no longer works. The following error is in the log:
16-03-26 22:31:18 homeassistant.components.device_tracker.icloud: Logging into iCloud Account
16-03-26 22:31:18 homeassistant.components.device_tracker: Error setting up platform icloud
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/device_tracker/init.py”, line 127, in setup_platform
if not platform.setup_scanner(hass, p_config, tracker.see):
File “/usr/local/lib/python3.4/dist-packages/homeassistant/components/device_tracker/icloud.py”, line 40, in setup_scanner
verify=True)
File “/home/vanbrunt/.homeassistant/lib/pyicloud/base.py”, line 152, in init
self.session.cookies.load()
File “/usr/lib/python3.4/http/cookiejar.py”, line 1765, in load
self._really_load(f, filename, ignore_discard, ignore_expires)
File “/usr/lib/python3.4/http/cookiejar.py”, line 1864, in _really_load
magic = f.readline()
File “/usr/lib/python3.4/codecs.py”, line 319, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0x80 in position 0: invalid start byte
