@rossk
It sounds like the zone info in the ios app did not pick up the stationary zone and the ios app is out of sync with the zones in HA.
Force close the iOS App on the phone, then reload it. Open the iOS App, go to Location, scroll down and see if the Stationary Zones are listed. If so, you should be OK. If not, restart HA when you can and then repeat above.
Changed the icon for zones from mdi:cellphone-iphone to mdi:cellphone because of Home Assistant mdi update.
Changed the sensor state values for Travel Time, Distance, Next Update Time, etc. from an empty field to a value to address a Lovelace display change. The fields that were empty were not aligned with the field next to them. Travel Time will now display 0 min when in a zone. Other fields will display â___â when empty.
Increased the Waze Route Server retry requests from 3 times to 6 times to try to resolve âNo response from Waze Server, Calc will be used insteadâ message.
@Zucht
The iCloud v2.4.6 HACS update has been fixed. I forgot to include the icloud3.zip file in the Release that HACS uses. Retry the HACS update again.
If iCloud3 doesnât show up in HACS pending updates:
Select Integrations,
Type icloud3 in the search bar
Click the 3-dots in the lower right corner of the iCloud3 panel
I am lost with this. After you install it thru HACS what you do after. I know there is a lot of documentation but I canât seem to understand how to get to the configuration screen or where to go for that matter.
@Tismo
The current version of iCloud3 uses yaml files (configuration.yaml, config-ic3.yaml) for configuration information. The Getting Started section of the iCloud3 documentation here explains the steps needed to configure and use iCloud3.
The next major version of iCloud3 will be handled as a true HA Integration with on-line configuration entry instead of yaml files,
@gts72
Yes, you need to set up remote access. This lets you use the iOS app to track your phone or other devices. The iOS app triggers entering and exiting zones, along with providing location updates along with the data provided from iCloud location services. Use letsencript/duckdns (HA integrations) and step up 2-factor authentication for HA access to secure your Pi.
Iâve been using iCloud3 for quite some time now and generally itâs quite reliable. I use it on my phone, alongside hte HA app, on the in-laws phones as FmF devices, and on my families phones with family sharing.
Sometimes, like today, some of the devices just wonât update their location. My family phones, setup using family sharing, are saying theyâre home, but they arenât. In FindMy, theyâre showing the correct location, but IC3 just wonât pick this up - Iâve tried pausing and resuming polling, restarting IC3, updating the location, etc. and it still says theyâre home.
Any idea why?
I see same issue. (iOS 15.x) sometimes my or my partners location is still far outside the house radius, it takes long time to change this. When I use find my app and update location of my partner then its inside the house radius but not updated in iCloud3.
