@Snuffy2
What is your configuration.yaml or config_ic3.yaml?
configuration.yaml
device_tracker:
- platform: icloud3
username: my_appleid
password: my_appleid_password
event_log_card_directory: 'www/community/icloud3'
config_ic3.yaml
devices:
- device_name: my_iphone
email: my_appleid
iosapp_suffix: '_app'
- device_name: wifes_iphone
noiosapp: true
- device_name: sons_iphone
noiosapp: true
@Snuffy2
You can set the devices to track to the other house in config_ic3.yaml using the track_other_zone parameter. Using that, it will track the āother_houseā and the āhomeā zone
devices:
email: my_appleid
noiosapp: true
track_other_zone: other_house
noiosapp: true
One issue is not using the iOS App on the other devices. You will not get zone enter/exit and any location update triggers from the iOS App. When you leave a zone, the exit is not recognized until the next polling interval which could be 2-hours later. See here for more info.
I could not find script.gary_leaves_zone
in the example docs. Also could you please provide your code for input_boolean.ha_started_flag
in the example docs. Thanks, Stefan.
Thanks for the clarifications. I had missed the info in the documentation that you linked to.
As for track_other_zone, I had tried that previously and again when you mentioned it and I canāt seem to get it to work. It always throws an error.
iCloud3 Error decoding `/config/config_ic3.yaml` parameters > The following parameters can not be handled: track_other_zone: other_house
Iāll private message you the actual log and config files with the real names as well.
There is a bug handling the unit_of_measurement: km parameter when it is specified in config_ic3.yaml and occurs when iCloud3 is restarted using Event Log > Actions > Restart iCloud3. The ākmā is displayed correctly on the screen but the value is the miles value, not the km value.
This does not happen if:
- the unit_of_measurement: km is specified in the configuration.yaml file
- the unit_of_measurement: km is specified in the config-ic3 file and iCloud3 is restarted by restarting HA instead of using Event Log > Actions > Restart iCloud3
This has been fixed in v2.3.1 that is available in the v2.3.1 Development Directory here.
I had checked that, just overlooked that gary_arrives_home, gary_leaves_home,gary_leaves_zone
are all automations, while gary_status, gary_arrives_home
and notify_gary_iphone
are scripts. The flag input_boolean.ha_started_flag
is used in these scripts - but the docs do not show how it is defined.
Here is another question: for some reason or the other my equivalent of script notify_gary_iphone
does show only (mobile app) on my phone - no title and no message. Any idea, why?
notify_swaiphone:
alias: 'Send Message to swa'
sequence:
- service: notify.mobile_app_swaiphone
data_template:
title: "{{ title }} (mobile_app)"
message: "{{ message }}"
The section of the automation reads
- service: script.notify_swaiphone
data_template:
title: Dammit
message: 'Zone: foo --> foo , Distance: 1234'
It seems the parameters donāt get passed to the script.
@swa72
I would look in the documentation of the iOS app. Itās been a while since Iāve been there but there are examples of how to use the notify service. There might also be some info on the iOS app forum.
Thanks for the hint. Googled a bit and found a solution in
title: Dammit
Note that there is no data_template
@gcobb321 I wanted to take a moment to thank you for this outstanding extension! Itās so much better than what is cooked into HA right now by miles (travel time TBD ).
Do you know what kind of impact the refreshes have on the battery of an iPhone? It seems like since I got this up and running that the iPhones drain significantly faster.
Thank you again!
Does the Travel Time sensor represent how far away āas the crow fliesā or does it use intelligence to determine the travel time based on the fastest route along roads? I know this is a feed from Apple and not calculated by iCloud3, Iām just wondering if anyone knows the answer to that.
@CO_4X4
Travel Time is not returned from Apple but returned from the Waze, along with the zone_distance value. The value is determined by passing the home (or other zone) gps coordinates and the gps coordinates from iCloud Location Services to Waze.
See a description about Waze here for more information.
Hi, thanks for your app.
Iāve got an error in the log, for the 2 devices iāve declared.
iCloud3 Setup Error > iphonedeyohann > The iOS App device_tracker entity was not found in the Entity Registry for this device.
What did i miss?
Ok, iāve read again the docs and found this:
The following parameters must be in the HA configuration.yaml file
username/password
tracking_method: iosapp (if using the iOS App tracking method, not needed for normal operations)
create_sensors
exclude_sensors
entity_registry_file_name
config_ic3_file_name
Here is my configuration.yaml:
#interdiction du log icloud3 dans HA History
recorder:
purge_keep_days: 3
exclude:
entities:
- sensor.icloud3_event_log
#paramĆØtres pour chaque device surveillĆ© par icloud3
device_tracker:
- platform: icloud3
username: xxxxx
password: xxxx
#exclude_sensors: batstat,lzonn,lzont,name
- platform: icloud3
username: xxxx
password: xxxxx
I donāt know how to write the missing parameters because the docs shows an example with only those params.
Thanks for your help.
@MoPepettes
Information about this can be found in the iCloud3 documentation in 1.6-configuring-starting-icloud and in 1.4-setting-up-iosapp.
All the other parameters can be specified in the config_ic3.yaml file described in 1.6-configuring-starting-icloud3.
iām sorry, iāve read several times but i donāt know what to do.
Here is the errors:
Iāve activated those params:
# --Track Devices Parameters-------------------------------
devices:
- device_name: iPhone de Yohann
email: xxxxx
# picture: gary.png
- device_name: iPhone XR Christelle
email: xxxxx
# picture: lillian.png
# noiosapp: False
iosapp_suffix: _app
# iosapp_entity: gary_iphone_app
# zone: warehouse
event_log_card_directory: 'www/custom_cards'
I thought the iosapp_suffix would resolved the errors but no luck.
@MoPepettes
The device_name parameters are incorrect. They need to be:
- iphone_de_yohann, not iPhone de Yohann
- iphone_xr_christelle, not iPhone XR Christelle
The spaces in the name are removed instead of converting them to ā_ā.
I was updating HACS to v2.3.1 but will make a change to accept the values you specified before I do the update.
