Edit: fixed by editing file to put double quotes around version number.
Hi. Love, love, love this integration.
Not running for me on Core 2021.2.2
2021-02-09 20:51:14 ERROR (MainThread) [homeassistant.bootstrap] Error setting up integration device_tracker - received exception
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 835, in async_forward_entry_setup
result = await async_setup_component(self.hass, domain, self._hass_config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 57, in async_setup_component
return await setup_tasks[domain] # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 64, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 174, in _async_setup_component
processed_config = await conf_util.async_process_component_config(
File "/usr/src/homeassistant/homeassistant/config.py", line 826, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 475, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 480, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 779, in exec_module
File "<frozen importlib._bootstrap_external>", line 916, in get_code
File "<frozen importlib._bootstrap_external>", line 846, in source_to_code
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/icloud3/device_tracker.py", line 25
VERSION = '2.3.2"
SyntaxError: EOL while scanning string literal
2021-02-09 20:51:14 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
VERSION = '2.3.2"
