iCloud3 & Watchman
I’m trying to clean up my HA install using watchman and its picked up a lot of icloud3 references.
Can someone point in the direction of how I fix it without breaking all what I have which tbh is only 1 iPhone but I have a lot of integrations with it.
> script.icloud3_command_resume_ | missing | custom_components/icloud3/sample-lovelace-cards/ui-          |
> | polling                        |         | lovelace_commands.yaml:10                                    |
> | script.icloud3_command_pause_p | missing | custom_components/icloud3/sample-lovelace-cards/ui-          |
> | olling                         |         | lovelace_commands.yaml:11                                    |
> | script.icloud3_command_restart | missing | custom_components/icloud3/sample-lovelace-cards/ui-          |
> |                                |         | lovelace_commands.yaml:12                                    |
> | script.icloud3_set_interval_1_ | missing | custom_components/icloud3/sample-lovelace-cards/ui-          |
> | min                            |         | lovelace_commands.yaml:14`
device_tracker.gary_iphone     | missing | custom_components/icloud3/sample-lovelace-cards/ui-lovelace- |
> |                                |         | home-whse_5x2.yaml:18,71                                     |
> | sensor.gary_iphone_interval    | missing | custom_components/icloud3/sample-lovelace-cards/ui-lovelace- |
> |                                |         | home-whse_5x2.yaml:20                                        |
> | sensor.gary_iphone_travel_time | missing | custom_components/icloud3/sample-lovelace-cards/ui-lovelace- |
> |                                |         | home-whse_5x2.yaml:23                                        |
> | sensor.gary_iphone_zone_distan | missing | custom_components/icloud3/sample-lovelace-cards/ui-lovelace- |
> | ce                             |         | home-whse_5x2.yaml:26
and then a bunch of Lillian ones.
How do I safely remove all this?
In the end I just deleted everything in the sample folder and it all went away.
Not ideal as I’m sure that’s there to copy/paste from but hey.
