ICMP binary sensor? aka Is host online?
I searched the home-assistant website but couldn’t find anythin about it. I simply want to trigger an action, if a host in my network is available. Is there such a machanism? Something like an ICMP/ping sensor? I came to the device tracker but the group.all_devices state would change to home although I am not at home, just because my NAS has been remotely started.
Did someone else ever ran into the same problem?
I added a new example to Command Line Binary Sensor with shows how to check the state of a system with ping.
Many thanks. I didn’t know about the command line platform. :slight_smile: This will lead to a whole new set of options in triggering events.
Does anyone have a working example they can share?
I am attempting to ping a binary sensor as shown below
binary_sensor 1:
  • platform: command_line
    command: ping -W 1 -c 1 192.168.0.3 > /dev/null 2>&1 && echo success || echo fail
    device_class: connectivity
    payload_on: “Up”
    payload_off: “Down”
I have two issues.
  1. The devices appear as “off”, despite the fact that I can execute the command from cli and exit with “success”
  2. Should the payload values override “on” “off”. I am trying to have Up/Down
