It seems that ping has moved into its own integration, previously I had added the cellphones manually in the configuration.yaml file. Under the new integration, for each IP addresses there are two entities created:
- Binary sensor which shows if the device is connected
- Device tracker entity which is perpetually showed in a state of “unavailable”
So I’m unable to set the person’s status using 2) above. I also tried creating my own device_tracker using a template but that did not work either.
Is this the expected behavior of Ping integration or am I doing something incorrectly in the above configuration?
