Icon color based on fan speed?
Is it possible to set the icon color if I’m using ‘custom:multiple-entity-row’ based on the speed of my fan?
This is the code I currently have:
type: entities
entities:
  - entity: fan.emilie_s_office_purifier_fan
    type: custom:multiple-entity-row
    secondary_info:
      attribute: percentage
      unit: '%'
    state_color: true
    toggle: true
    show_state: false
    entities:
        icon: mdi:power-off
        state_color: true
        tap_action:
          action: call-service
          service: fan.set_percentage
          service_data:
            percentage: '0'
            entity_id: fan.emilie_s_office_purifier_fan
        icon: mdi:circle-slice-2
        state_color: true
        tap_action:
          service_data:
            percentage: '25'
        icon: mdi:circle-slice-4
        state_color: |-
          {% if is_state('light.ignacio_s_office', 'on') %}
            amber
          {% endif %}
        tap_action:
          service_data:
            percentage: '50'
        icon: mdi:circle-slice-5
        tap_action:
          service_data:
            percentage: '75'
        icon: mdi:circle-slice-8
        tap_action:
          service_data:
            percentage: '100'
Basically, I want that 25% to be highlighted and the other icons to be grayed out if the speed is 25%
Thanks!
Have you looked into installed Card-mod from HACS? It will do exactly that. I use it in very similar ways on all sorts of devices.
Thanks @CO_4X4 . Could you share an example for how you use it?
Here’s one I use for my vacuum power level:
show_name: true
show_icon: true
type: button
tap_action:
  action: more-info
entity: vacuum.roomba_upstairs
show_state: true
hold_action:
  action: none
card_mod:
  style: |
    ha-card {
    --ha-card-background:
      {% if states('vacuum.roomba_upstairs') == 'cleaning' %}
        #40ff00;
      {% elif states('vacuum.roomba_upstairs') == 'paused' or states('vacuum.roomba_upstairs') == 'returning to dock' %}
        #00bfff;
      {% elif states('vacuum.roomba_upstairs') == 'error' %}
        red;
      {% else %}
        #fff;
      {% endif %}
    --paper-item-icon-color:
      {% if states('sensor.roomba_upstairs_battery_level') | int <= 100 and states('sensor.roomba_upstairs_battery_level') | int >= 75 %}
        forestgreen;
      {% elif states('sensor.roomba_upstairs_battery_level') | int < 75 and states('sensor.roomba_upstairs_battery_level') | int > 30 %}
        orange;
      {% elif states('sensor.roomba_upstairs_battery_level') | int <= 30 %}
        #ff4000;
      {% else %}
        #fff;
      {% endif %}
    color:
      {% if states('vacuum.roomba_upstairs') == 'paused' or states('vacuum.roomba_upstairs') == 'error' %}
        white;
      {% else %}
        #000;
      {% endif %}
