Lecso11
(Lecso11)
March 20, 2024, 8:57am
1
Hi!
I’m trying to change icon color based on entity state with card-mod.
It switches to green with my TV, and back to default white when off, but the fan stays green even after switching it off. The icon changes to the crossed fan icon when off, but the color stays green.
If I refresh the webpage, the icon refreshes to the default color.
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: media_player.lg_tv
content_info: name
use_entity_picture: false
tap_action:
action: call-service
service: script.lg_tv_toggle
hold_action:
action: more-info
card_mod:
style: |
:host {
--card-mod-icon-color:
{% if is_state('media_player.lg_tv', 'on') %}
green;
{% endif %};
- type: entity
entity: fan.smart_fan
tap_action:
action: toggle
content_info: name
card_mod:
style: |
:host {
{% if is_state('fan.smart_fan', 'on') %}
green;
{% endif %};
tom_l
March 20, 2024, 9:04am
2
That’s because you did not tell it what to do if off (only on):
Try adding an else
case.
You don’t have to use car_mod for the icon color change if you switch to the template version of Mushroom-Chips-Card.
You can template the color in icon_color:
chips:
- type: template
icon: mdi:television
icon_color: |
green
{% else %}
red
{% endif %}
content_info: name
tap_action:
hold_action:
action: more-info
- type: template
icon: mdi:fan
icon_color: |
yellow
{% else %}
blue
{% endif %}
tap_action:
action: toggle
content_info: name
Lecso11
(Lecso11)
March 20, 2024, 10:10am
4
I tried that, didn’t make a difference, and I don’t think it should be the issue, because the TV works without an else case.
Edit:
Sorry, you are right, I formatted my code wrong, that is why it didn’t work.
This works:
card_mod:
style: |
:host {
green;
{% else %}
white;
{% endif %};
However, white is not the default color. Do you know what is? Now there is a slight difference between the default white icons and my white icons.
Lecso11
(Lecso11)
March 20, 2024, 10:25am
5
This didn’t refresh either, and makes it a bit more complex if I want the icons to change when the state changes, which was done by default in my config. With this I should template the icons too.
It is a different approach, and could be a solution, thank you!
tom_l
March 20, 2024, 10:26am
6
Use this instead of white;
var(--state-icon-color);
This will pick up whatever your theme has the icon colour set as.
Lecso11
(Lecso11)
March 20, 2024, 10:43am
7
Hm, this made them blue, which is correct, but then, how can I find out what the default color is in the Mushroom Chip card?
Lecso11
(Lecso11)
March 20, 2024, 11:17am
8
Found it by trial and error: light gray
You can always use the Chrome Dev tool or look in the JS to see what is being assigned as the default color.
