Icon color does not change anymore according to the scene/automation
I have Lidl Livarno Lux HG06106B color bulb, for which I have made 2 color scenes, the other one red and the other green. I use automation to switch the scene according to electricity price.
I use it to signal other family members when to use washing machines etc. because of vastly varying electricity price. I cannot let them go to the HA, because there seem not to be decent user access control in Home Assistant.
Anyway, I just noticed that the entity icon (yes, entity icon, not scene, which does not work…) does not anymore change its color according to the bulb color, like it used to. It has been working OK for a long time (somewhat 8 months or so). Automations switch the scene OK, and the bulb color changes OK, but not the icon.
The color wheel does not show changed scene color either. If I activate the red scene with automation, this is how the color is set:
also the icon is set set accordingly. However, if the green scene is set, the color wheel and icon looks exactly the same, showing red, however the bulb color changes OK.
It does not matter, what colors I choose nor if I set them manually, the last setting stays visible in color wheel and in icon and do not react to changes after that. The automations and scenes under the hood works OK and bulb colors change accordingly.
If i after the change toggle the on /off swith of the entity, both color wheel and icon show right color according to scene setting. This was not needed before. What gives?
RaspPi 4 4GB, Home Assistant 2023.1.7, Supervisor 2022.12.1, Operating System 9.4, Frontend 20230110.0 - latest, Conbee II + deconz addon
