Seems like i can’t get icon_color get to work.
Color must be yellow, but it isn’t changing.
It does say the rgb color, but what is wrong?
Running on 0.82.0.
sensor.hass_update_available:
templates:
_stateDisplay: "if (state === 'No') return 'No update available'; else return 'Update available';"
icon: "if (state === 'No') return 'mdi:check'; else return 'mdi:cellphone-arrow-down';"
rgb_color: "if (state === 'No') return [253, 216, 53]; else return [68, 115, 158];"
use icon_color.
this will only work if you have custom-ui installed.
templates:
icon: >
if (state === 'on') return 'mdi:wifi';
return 'mdi:wifi-off';
icon_color: >
if (state === 'on') return 'rgb(251, 210, 41)';
return 'rgb(54, 95, 140)';
you can use any Css color. https://github.com/andrey-git/home-assistant-custom-ui/blob/master/docs/features.md#icon-color
That did the trick.
I was missing some lines.
frontend:
extra_html_url:
- /local/custom_ui/state-card-custom-ui.html
extra_html_url_es5:
- /local/custom_ui/state-card-custom-ui-es5.html
customizer:
custom_ui: local
