and that works,
but before uploading, I used some testimages from the internet,
and those test images automatically changed color up on state change, I didn’t have to upload them twice. but I do.
what do I need to do to automatically change the color and only use one image?
I tried the last part and it’s cool.
but I found that it applies grayscaling the trasparent part stays transparent.
I my example image I just didn’t have enough color to notice.
sorry i don’t think i understand. are you saying the color differential isn’t good for what i did to your name/profile image? if so, i just grabbed it and threw together in literally 10 secs.
for you, if you want to do this method instead of having 2 images, you can muck around with your color intensity so it’s more like mario… is that what you’re asking about? or something else?
yeah, true point. you’re right. to the extreme, you could have 1 pix or none… the key point is that the system grayscales out the png. . regardless of transparency… the transparency does let the system show through the back and such.
