mmiller7
(Matt Miller)
January 28, 2021, 12:18am
1
I’m trying to make a sensor to monitor which ISP my internet is going thru (I have redundant ISPs)…I got the sensor working but it only shows with a generic “eyeball” icon. I’d like to use something like mdi:earth
since it is the internet gateway.
I’ve tried icon: mdi:earth
but it seems icon is not valid for command line sensors?
- platform: command_line
command: 'dig -x $(curl --connect-timeout 5 -s http://checkip.dyndns.org | sed "s/.*<body>Current IP Address: //;s/<\/body>.*//") +short | awk -F ''.'' ''{ print $(NF-2) "." $(NF-1) }'' 2>/dev/null || echo "Unknown"'
scan_interval: 20
command_timeout: 15
How can I set the icon for this to something more appropriate to “internet”?
tom_l
January 28, 2021, 4:18am
2
Use customize for integrations that don’t support an icon:
mmiller7
(Matt Miller)
January 28, 2021, 7:47pm
3
I’m apparently failing to do something…
Error:
2021-01-28 14:45:29 WARNING (MainThread) [homeassistant.config] Package network_monitoring contains invalid customize
Code:
name: "Outbound Public IP"
command: 'curl --connect-timeout 55 -s http://checkip.dyndns.org | sed "s/.*<body>Current IP Address: //;s/<\/body>.*//" 2>/dev/null || echo "Unknown"'
scan_interval: 20
command_timeout: 10
scan_interval: 20
command_timeout: 15
homeassistant:
customize:
- sensor.outbound_public_ip:
icon: mdi:earth
- sensor.isp:
icon: mdi:earth
Maybe someone else sees what it still doesn’t like?
It’s ok to have homessistant: in a package as well.
I think your sensor isn’ t a sensor.
Isn’t it command_line.outbound_public_ip etc?
Also I think your indenting is wrong. Here is one of mine:
sensor.wan_ip_address:
friendly_name: WAN IP Address
icon: mdi:server-network
mmiller7
(Matt Miller)
January 29, 2021, 3:03am
6
In developer tools I don’t have a command_line.outbound_public_ip but I do have a sensor.outbound_public_ip so I thought that was the thing to use?
ok that is right then. I don’t have any command line sensors…
You don’t need the - in front of the customize entries (at least I don’t have them in mine)
mmiller7
(Matt Miller)
January 29, 2021, 3:18am
8
YAY! It was the ‘-’ in front of the list entries.
