RitteT
(RitteT)
1
Hi, I’m trying to change the icon in my binary sensors but this doesn’t seem to work? Can I have your input please?
sensors:
issleep:
value_template: '{{ is_state("input_boolean.issleep","on") }}'
icon_template:'{% if is_state("binary_sensor.issleep","off") %} mdi:sleep-off {% else %} mdi:sleep{% endif %}'
friendly_name: 'Sleeping'
payload_on: 'True'
payload_off: 'False'
chrio
2
I’m not good at those so this might not be the issue, but aren’t you missing a single quote to end the icon_template line?
RitteT
(RitteT)
3
Yes, that got lost when I pasted the coded. It’s there in the code ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
chrio
4
Hmm, try testing the icon_template line against “False” instead of “off” and see if it helps.
This is my reasoning:
This generates a value that is True or False
value_template: ‘{{ is_state(“input_boolean.issleep”,“on”) }}’
But here you check if it’s value is ‘off’ or if it’s something else:
icon_template:‘{% if is_state(“binary_sensor.issleep”,“off”) %} mdi:sleep-off {% else %} mdi:sleep{% endif %}’
And since off is never the same as either True or False, the icon should only be mdi:sleep.
