Icons at the topbar
How can I change the names into icons at the topbar? It seems I can’t find anywhere to change the entities from names to icons, but I’ve seen many screenshots where for example “Home” has the icon of a house or “lights” the icon of a lightbulb.
I would love to change them by local files if possible.
So what I did try:
  • Customization: seems I don’t have the topbar inside the entity list?
  • Configure UI: click on the “name” to get the “View configuration”, then fill in at “icon (optional)”: local/filename.png. (the file is at config/www) Doesn’t work at this point :frowning:
Probably it will be something simple I’m overlooking.
You can only use MaterialDesignIcons.
20191115_11%3A49%3A49_001
Didn’t know that’s the only way to go… Had thought about this before, but wanted to use “own” icons. Will use MDI instead for this.
Thank you!
