ICONS Default v Cusomising Single devices
Hi All,
Sorry for a simple question but I have been searching for a while and cant work something out.
On my pretty much standard hassio install I have movement sensors showing a round ring. If they sense change then their is a check mark (tick) placed in a coloured circle to indicate movement.
I want to change this to a standing and running man with colour from green (standing) to red (running).
I have changed some icons for specific entitites through the customizations page with mdi: but I want to know can I change all movement sensors/icons with a single piece of work or do you need to manually customize each entity.
cheers
If you name them in a specific way, that they are distinguishable from other sensors you can do it with global customization. Otherwise just do it manually, in my opinion this is still faster than through the UI. Check the customize docs for further info.
Thanks Burningstone, out of curiosity how does HA default set icons. Is their a file that can be manipulated or is it untouchable.
