Icons not showing
I have a weather-forecast card (meteo-france entity) on my dashboard, but no icons is showing. If I try to edit the card, the icons are ok.
In dashboard:
In edit mode:
I tried to clear all cache from browser without any success.
The dashboard is display on a tablet using the home assistant app. I tried to reinstall the app and clear all data and cache whithout success.
I’ve seen on another post that the weather-forcast type has been removed few month ago, but all was running well until the end of august month (I follow all upgrades of home assistant).
Any idea please ?
I’ve found something. It seems that if I apply a theme on the vue or directly on the weather component, the icons are not showing. I had to remove the theme configured on the view and apply the theme on each other component.
But it looks like a bug ???
Open up the web developer console in your browser and check the network tab, if you see 404 not found errors for icons located in the /hacsfiles/themes/ directory, it’s likely to due to HACS 2.0 no longer supporting /hacsfiles for themes.
If the theme hasn’t been updated to support HACS 2.0, I found a working solution here Problem since last home assistant core update. · Issue #32 · ricardoquecria/caule-themes-pack-1 · GitHub
