Hi
I have two tabs with icons, one with home and the other with proximity-sensor in the groups.yaml:
automations:
icon: mdi:home
view: yes
entities:
- automation.Boiler_and_Heater_Winter_On
- automation.Boiler_and_Heater_Winter_Off
- automation.Heater_Deep_Winter_On
- automation.Heater_Deep_Winter_Off
# - automation.Bolier_Deep_Winter_On
# - automation.Boiler_Deep_Winter_Off
- automation.Heater_Spring_On
- automation.Heater_Spring_Off
sensor_tab:
icon: mdi:proximity-sensor
view: yes
entities:
- group.Vestiario_Sensors
The home works, but the other doesn’t
I don’t see any errors on the system log related to the tabs, only what I think is the mosquitto broker taking a long time to connect:
19-04-29 16:29:22 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:29:22 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:29:27 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:29:28 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:29:28 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:29:33 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:29:33 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:29:33 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:29:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:29:39 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:29:39 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:29:44 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:29:44 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:29:44 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:29:49 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:29:50 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:29:50 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:29:55 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:29:55 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:29:55 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:01 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:01 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:01 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:06 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:07 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:07 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:12 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:12 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:12 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:17 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:18 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:18 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:23 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:24 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:29 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:29 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:29 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:34 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:35 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:35 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:40 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:40 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:40 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:46 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:46 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:46 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:51 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:52 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:52 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:30:57 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:30:57 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:30:57 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:31:03 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:31:03 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:31:03 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:31:08 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:31:09 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:31:09 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:31:14 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:31:15 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:31:15 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:31:20 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:31:20 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:31:21 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:31:26 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:31:26 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:31:27 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:31:32 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:31:32 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:31:33 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-29 16:31:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:31:38 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:31:39 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-04-29 16:32:30 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:32:30 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:33:22 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-29 16:33:22 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-04-29 16:33:30 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-04-29 16:43:38 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-04-29 17:13:41 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
I’ve cleared chrome cache:
https://techzillo.com/clear-cache-one-website-chrome/
used another computer, used another browser, and the result is still the same.
I’ve used several icons I found in here:
And for what I read were supposed to work.
Do I have to install any thing?
Which icons do I have available?
Thank you in advance
