For “contains” and “startswith”, is there an option to search for multiple terms?
Sorry but no
Sorry for not noticing that - too busy at work and thus for this Mega-Delay:
I just made a sensor… not very beautiful, but it does the job:
sensors:
gcoll_next_date:
icon_template: mdi:truck
friendly_name_template: >
{% set r1 = state_attr('sensor.ics_1', 'remaining') %}
{% set n1 = state_attr('sensor.ics_1', 'friendly_name') %}
{% set r2 = state_attr('sensor.ics_2', 'remaining') %}
{% set n2 = state_attr('sensor.ics_2', 'friendly_name') %}
{% set r3 = state_attr('sensor.ics_3', 'remaining') %}
{% set n3 = state_attr('sensor.ics_3', 'friendly_name') %}
{% set r4 = state_attr('sensor.ics_4', 'remaining') %}
{% set n4 = state_attr('sensor.ics_4', 'friendly_name') %}
{% set min = (r1, r2, r3, r4) | min %}
{% set remainings = (r1, r2, r3, r4) %}
{% set types = (n1, n2, n3, n4) %}
{%- for r in remainings -%}
{%- if (r == min) -%}
{{ types[loop.index0]}}
{%- if not loop.last %}/ {% endif -%}
{% endif -%}
{% endfor %}
value_template: >-
{% if min == 0 %} Heute {% endif %}
{% if min == 1 %} Morgen {% endif %}
{%- if min > 1 %} in {{min}} Tagen {% endif -%}
attribute_templates:
type: >-
{% for r in remainings %}
{% if (r == min) %}
{% endif -%}
{% endfor %}
days: >-
{{min}}
Hope it helps…
Hi There
could anybode let me know how to integrate a local stored calender into ICS. It’s stored on my SDD (use HA on a PI4), so how to address the local folder? I have tried several options as described, but no success. Even not with the external link stored/showed in the description. Thank you for any help.
On an external link I get: “The downloaded file can not be parsed, not a valid ICS file.”
Any help??
JJ
Thank you for the Template. I modified a little the friendly_name_template
and replaced the for loop (to be able to remove the last slash):
{%- set types_joined -%}
{%- set pipe = joiner(' / ') -%}
{%- for r in remainings if (r == min) -%}
{{ pipe() }}{{ types[loop.index0] }}
{%- endfor -%}
{%- endset -%}
{{ types_joined }}
(inspired by home-assistant/core#Missing jinja extension: Expression statement)
will be this integration updated or can i remove it in future core updates?
Hopefully it’s gonna be fixed, I use it every day!
No worries
