Hey guys, I’ve published a little custom-component (available in HACS as well) called ICS.
One can specify an ics file, e.g. from a trash-pick-up provider or the office birthday calendar and it will generate a sensor that displays the date, title and remaining days to the next event.
It also gives you the option to filter for event titles, so you can create multiple sensors with the same ics file and different filter, e.g. for multiple types of trash at one service provider.
@JKW: very nice job for the calendar component which is becoming more and more flexible! I already worked on it to first be able to also load local ics files which you now also have provided… One missing addition was the ability to define an icon from the config of the sensors which I locally realized as you can see here:
Wow! I am impressed how quick you implemented it ! I locally did it almost the same to your approach as I have checked your changes. But you added for logging which is also excellent which I saw when I was logging my system at DEBUG level - could be a role model for others
Already checked it and it works as expected! Thanks a lot!
I am using your integration last couple days and we like it a lot. I was trying to get google home announce the trash pickup one day before, but I can’t get it to work. I am trying only one of the entities but get no announcement.
This is what I was trying without script example:
EDIT: It was spacing issue, the config check did not give errors, but after playing a lot with spaces I got it working.
Notify pb and pb_c are my notification services (in my case Pushbullet) … you have to replace that with whatever service you want to use for notification
Jkw
Hey Hauke, can you tell me how you got the “Nächste Abholung” row in your card?
@JKW Thank you for the great intergration, made a real useful tool in our lovelace :-). Is there an easy way to translate the weekdays in another language?
Hi, not really … as this is done in the backend and that will only provide English output.
I guess the easiest would be to add a template sensor like this …
@JKW Really a great component. Thanks a lot for that.
As I have read in your documentation there should be a way using config flow instead of manually add the sensors to the configuration.yaml? Or did I understand something wrong? I searched a lot about config flow but could only find out that this is some kind of technical possibility to integrate a component…
