ID for KNX Scene
In scenes.yaml file i have many Home Assistant scene and two KNX Scene.
If I modify a Home Assistant scene when saving, the ids are inserted for all the scenes contained in the scenes.yaml file.
But the Configurator Check gives an error because in the KNX scene it is not possible to insert the id field
https://www.home-assistant.io/integrations/scene.knx/
